99 3.2 liter engine will not stay running or start without throttle pressed? #628239 07/20/05 01:51 AM
NATO308 Offline OP
I have a 99 3.2 liter Amigo that has developed a problem that has me stumped. It will not start without depressing the gas pedal. It turns over easy and sounds like it is trying to start but will not run unless the gas pedal is depressed slightly and will not idle without continuing to press on the gas pedal. As soon as I let up on the throttle, it dies. Anyone seen this before? It is an intermittent problem, as it happened a couple weeks ago, it went away after changing the fuel filter. The problem came back and I changed the fuel regulator, the problem went away again. But now it is back, again. Any ideas?
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: NATO308] #628240 07/20/05 01:25 PM
Bigpoppax2 Offline
Have you checked your fuel pressure? It may be a fuel pump problem.
Joe
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: NATO308] #628241 07/20/05 01:37 PM
W
Wayne Offline
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: NATO308] #628242 07/20/05 02:32 PM
litnin Offline
Sounds like it might be the idle air control valve/solinoid sticking and not allowing the air to bypass the throttle blade at idle. When you crack the throttle open slightly, you are allowing the engine to breathe again.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: NATO308] #628243 07/21/05 03:13 AM
troopinn Offline
I had the same problem that reared it's head half way through winter. Throttle body was all gummed up and needed to be cleaned. cleaned it out and Troopin again... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: Wayne] #628244 07/26/05 02:02 AM
JohnW Offline
"Common Fixes" suggested using Bosch Platinum4 plugs. However, they should not be used on newer isuzu's that have ion sensing through the plug. They are not compatible and cause the computer to register multiple misfires. Just a heads up before anyone spends the money.
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
Re: 99 3.2 liter engine will not stay running or start without throttle pressed? [Re: litnin] #628245 08/11/05 04:06 AM
NATO308 Offline OP
Thanks for all the help, it was indeed the idle air control valve. Replaced it, $40, now it starts and runs great again.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6188 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-06-07 04:13:03 UTC
