1990 runner - stalling problem #628372 07/20/05 03:27 PM
Hugh Offline OP
A friend of mine owns a 1990 runner that stalls a lot. Usually at stops or when going very slow.
Multiple attempted fixes at the Stealership and it still stalls <img src="/forums/images/graemlins/confused.gif" alt="" />
Any help?
Hugh
94' 4Runner SR5 3.0L, 4X4, 5-speed, 200K
01' Sienna XLE, 105K, auto everything...
91' Ford F-250, 7.3 liter IDI diesel, 5-speed, 170K
Re: 1990 runner - stalling problem [Re: Hugh] #628373 07/20/05 05:01 PM
Seattlegti Offline
Cracked air intake boot? Even a small hole will wreck havoc. I'm on my third since new.
Re: 1990 runner - stalling problem [Re: Hugh] #628374 07/20/05 05:36 PM
kuso Offline
I had the same problem w/ my 1991 Toyota Pick up. Turned out to be the PCV valve. Might wanna give that a shot! <img src="/forums/images/graemlins/smile.gif" alt="" /> It only costs about 7 bucks from the stealership too!
Don't forget the imfamous EGR valve! It might be filthy and sticking when it shouldn't, so give that a good cleaning or a good wrap w/ a hammer (thanx Darin <img src="/forums/images/graemlins/baby.gif" alt="" />) and see if that helps also. G'luck!
-kuso <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 Toyota, X-cab, 3.0, SR5, 4x4, Automatic Leech Tranny, 31" Generics, "KaTooM Carrier" 201K and runnin' smooth!
Many a good man has failed because he had his wishbone where his backbone should have been.
--Unknown
Re: 1990 runner - stalling problem [Re: kuso] #628375 07/20/05 07:23 PM
Hugh Offline OP
You guys rock! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I'll be checking out these possible fixes this week.
--Hugh
Re: 1990 runner - stalling problem [Re: Hugh] #628376 07/21/05 03:33 AM
kewlynx Offline
Also when you post back with your findings, tell us what the stealership did, or supposedly did, so it dials in the troubleshooting a bit.
**ubi apis- ibi salus**
Re: 1990 runner - stalling problem [Re: Hugh] #628377 07/21/05 03:46 AM
mudking82 Offline
If its an automatic transmission, it could be trouble with the TCC(torque converter clutch).
Jeremy
88 Toyota Pickup 22RE, 31x10.5's, Warn M8000, Marlin rear bumper
Re: 1990 runner - stalling problem [Re: kewlynx] #628378 07/22/05 07:18 AM
Hugh Offline OP
Yes, I will list the various attempted fixes that the dealer performed (and $$ charges...he he) as soon as I can.
I'm still waiting to see the 4runner in person and look it over.
More later,
Hugh
Re: 1990 runner - stalling problem [Re: Hugh] #628379 07/31/05 04:14 PM
Hugh Offline OP
Air intake boot is fine, but I found another hose with a very bad split. This is the larger of the two hoses that comes off of the smaller box connected to the air filter housing. Does this route unburnt fumes back into the engine?
Dealer replaced an O2 sensor to try to fix this problem a while back.
--Hugh
Re: 1990 runner - stalling problem [Re: Hugh] #628380 08/04/05 05:47 PM
Seattlegti Offline
Ever find the culprit?
Re: 1990 runner - stalling problem [Re: Seattlegti] #628381 08/05/05 02:58 AM
Hugh Offline OP
I work with the woman that owns the stalling 90' 4runner. She drove her other car everyday since I've gotten the new air hose replacement <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/sleeping.gif" alt="" />
I saw that the O2 sensor was replaced and the PCV valve and lots of other expensive general maintenance stuff.
I'll let you know what I find out, Hugh
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6366 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-07 03:06:30 UTC
