Any easy to tell if you've got a limited-slip? #628894 07/21/05 11:27 PM
Kmartin173 Offline OP
I've got a '90 Amigo that does not have the original rear-end in it. Is there a quick test to tell if its open or limited-slip?
Re: Any easy to tell if you've got a limited-slip? [Re: Kmartin173] #628895 07/21/05 11:33 PM
F
Frisky Offline
jack the back up and spin the tires. See if they turn together or in opposite directions. Someone correct me if this is wrong. Opposite direction is open and same direction is LSD right?????
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: Any easy to tell if you've got a limited-slip? [Re: Frisky] #628896 07/21/05 11:35 PM
onebadtrooper Offline
yeah, but it can't be in gear. other wise thats how you can check. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Any easy to tell if you've got a limited-slip? [Re: Kmartin173] #628897 07/21/05 11:38 PM
A
all we'll drive Offline
Look on the Pumpkin Housing, mine has a little decal on it the back of it (towards the rear bumper). It says "use only LSD oil"
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: Any easy to tell if you've got a limited-slip? [Re: all we'll drive] #628898 07/22/05 12:21 AM
Sc0rp10n Offline
IIRC Amigo's did not come with that option...someone else might disagree but I'm pretty sure they didn't.
Nick
Edit: My bad didn't see the "not original" part. Forget what I said!
Nick
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Any easy to tell if you've got a limited-slip? [Re: Sc0rp10n] #628899 07/22/05 02:53 AM
Opposite directions, thanks for the help.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6101 MB (Peak: 0.6798 MB) Data Comp: Off Server Time: 2026-11-03 03:04:17 UTC
