Head removal- help needed #57058 06/25/03 10:49 PM
jsanch Offline OP
OK, I started on the timing chain replacement on my 89 runner with 22re and when I removed the valve cover I noticed sludge in the rear driverside of the head so I have decided to do a valve job. I have removed all the bolts holding the intake to the head but the intake won't budge. I noticed that there is one bolt on the lower part of the thermostat housing and it does not have a "regular" bolt head, does it have to be removed also?? I took a pic to simplify matters
<img src="http://pics.montypics.com/jsanch/2003-06-25/1056576020_head3a.jpg" alt=" - " />
1987 Raider - auto, Weber carb, bouncy seat, 31 Coopers,
1989 4Runner 4 Cylinder All stock
Re: Head removal- help needed #57059 06/25/03 11:21 PM
Esquire812 Offline
Okay...if you are pulling the intake off of the head before removal...then yes. But I would advise pulling the intake with the head, then remove it on the bench..save you a pile of time and bandaids. Also did you make sure and pull the 12mm bolt that is hidden in the pool of oil under the distributor drive gear? Dont forget that your PAIR system piping and heater return are also bolted to the back of the head. Just go about things real careful like so you dont break a hard pipe, tweak the head or booger up any wiring. ~Darin <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Head removal- help needed #57060 06/25/03 11:32 PM
Frankenyota Offline
Yup that is one of the two "hidden" head/intake bolts. Take Darin's advice and pull the head/intake as a combo, it makes life easier, trust me on this one Darin has been pulling a lot of heads/intakes/engines lately :-P
1986 4X4, 1991 22RE, 5.71 gears,ARB Rear, aux fuel tank, 3mm O/S TB/intake, engnbldr cam, LCE header, magnaflow w/2.25 exh. custom 4 color paint job :-P 33X12.5 Goodyear MT/Rs
Re: Head removal- help needed #57061 06/26/03 02:14 AM
jsanch Offline OP
Thanks, guys. Sure is more complicated than my 87 Raider. Now, does anyone have a schematic for all the vacuum hoses??? I might have screwed up when I cleaned the throttle body, accidently knocked off the stickers I had placed. <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
Re: Head removal- help needed #57062 06/26/03 06:45 PM
Esquire812 Offline
<img src="http://www.cybrrpartspro.com/Chilton%20Images/8682/86824V11L.gif" alt=" - " />
There ya go. 1989-1990 22REC Federal/Canada
85' Sillyca 22R-Esq
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6053 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-06-20 16:31:56 UTC
