5spd interchangability - '85 22RE w/56 #629200 07/22/05 08:55 PM
NVR FNSH Offline OP
What year transmissions will bolt-in? Will the trans from a '95 V-6 bolt-in?
Brian
Re: 5spd interchangability - '85 22RE w/56 [Re: NVR FNSH] #629201 07/23/05 05:02 AM
matts Offline
Brian
I believe all W56 transmissions from '85 to about '91 will be a straight swap. They improved the W56 in the mid ninties, but they also changed the shifter positions a little, so you'd have to trim the tunnel opening if you get one of those. The '95 V6 had a different trans called the R150. You could make it work, but you would need an R151 bellhousing, which is hard to find and can run around $200 when you can. You'd also need to use the transfer case that came with the '95 trans and you probably have to do a little sheetmetal trimming on the tunnel where the shifters come through. There are probably lots of W56 trannys in the junkyard near where you live that you could get for $275. They are also on eBay all the time. You can also get a rebuilt for about $600 from the best Toyota tranny guru in the country, (see Marlin Crawler.com). They're in Fresno, in central Kalifornia. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5884 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-06-21 12:19:58 UTC
