Whats the trick w/ these $@## CV axles? #629476 07/23/05 07:07 PM
W
wave Offline OP
The BGB FSM says to unbolt the axle from the diff, remove the hub flange, and pull the axle out from the inside. Has this actually worked for anyone? I was about to get a tourch and start cutting!
Any tips or secrets?
95 4-runner w/ 3vze and a manual.
Anthony
Re: Whats the trick w/ these $@## CV axles? [Re: wave] #629477 07/23/05 08:38 PM
4Crawler Offline
Here is one way to do it:
http://www.off-road.com/toyota/cheaptricks/quickcv/
Or pull the lower ball joint to swing the spindle away a little to get some room.
Re: Whats the trick w/ these $@## CV axles? [Re: wave] #629478 07/24/05 05:04 AM
Snowtoy Offline
Yep, unbolt the ball joints and you will have all of the room you need. This is the only way I do it anymore on oem set-up rigs. To make it easier in the future, replace the studs with bolts.
Re: Whats the trick w/ these $@## CV axles? [Re: wave] #629479 07/24/05 05:27 AM
TheBandit Offline
I prefer to remove the upper balljoint so the whole thing swings down. But I haven't done that since replacing the inner axle studs with bolts - saves some headache!
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6013 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-05-29 15:14:58 UTC
