Isuzu wheel/interchangability among other isuzus and other makes???? #630588 07/27/05 06:54 PM
I own an 86/93 trooper and 94 amigo. Is the bolt pattern the same on these even though 86 are 15 inch? If so are all isuzu 4xs interchangable? Will other automakers wheels fit?Lastly,when describing my 93 troops 16" steel wheels how is it done?Im trying to buy used wheels/tires from paper but dont know all the lingo.TIA
Re: Isuzu wheel/interchangability among other isuzus and other makes???? #630589 07/27/05 07:07 PM
RobG Offline
all isuzu wheels are interchangable in the sense they use the same bolt pattern. many chevy's and toyota's also share this same pattern as well.
However, there are many differences in rim diameter, width, and offset that may cause rubbing/fitment issues even for a given sized tire.
-Rob
Re: Isuzu wheel/interchangability among other isuzus and other makes???? [Re: RobG] #630590 07/27/05 07:17 PM
Starchild Offline
The bolt patern on all Isuzus is 6 on 5.5. Meaning 6 lug on 5.5" radius.
The other characteristics of the wheels will be diameter, width, and either backspacing or offset.
HIH,
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Isuzu wheel/interchangability among other isuzus and other makes???? [Re: RobG] #630591 07/27/05 07:19 PM
Thamks RobYou said some toy/chevy rims fit.How do you know which? Is there alot of trial/error involved in tire/wheel/vehicle fitment? if so why has no one compiled this data?
Re: Isuzu wheel/interchangability among other isuzus and other makes???? #630592 07/27/05 07:25 PM
Jim_Paget Offline
The other variable is hub opening diameter. Some Chevy will work IF they came off a 4X4 with the large hubs.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Isuzu wheel/interchangability among other isuzus and other makes???? #630593 07/27/05 07:34 PM
RobG Offline
Well, I said some because as with most things, there is no absolute truth. Chevy used mostly the 6 on 5.5 pattern, but some of the newer vehicles more than likely imploy metric patterns and would not fit.
First and formost, the rim you choose will need to be a 6-lug on 5.5" pattern. Like Jim mentioned, you will need hub opening in two of the rims to accomodiate the your hublocks. rims off a 2wd may not have this, and some Chevy's use an opening that isn't large enough to accomodiate the isuzu hub. Beyond that, its a matter of choosing the appropriate width and offset so that you can clear the tire around the fender and suspension components.
Not one has compiled a list of this because the information is way to vast and individual setups differ. No auto manufactor used a single size rim. Even within particular model years, several rim configurations could exist. A rim size that allows me to run a particular 33" tire on my Isuzu may cause the next guy too much rubbing to even drive it on the street, etc...
-Rob
Re: Isuzu wheel/interchangability -Thanks everyone [Re: RobG] #630594 07/27/05 09:00 PM
Now i finally have a place to start."my amigo is like a friend to me"
Re: Isuzu wheel/interchangability among other isuzus and other makes???? [Re: Starchild] #630595 08/01/05 04:29 AM
maxwell417 Offline
6 on 5.5 diameter, not radius <img src="/forums/images/graemlins/smile.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Isuzu wheel/interchangability among other isuzus and other makes???? [Re: maxwell417] #630596 08/02/05 05:05 AM
Z
ZooMigo Offline
The stock rims from my 92 Amigo fit on my 99 Amigo, but not the other way around.
Kevin
White '99 5Speed Softie. Some extra custom junk. - RIP
Stock Pink 92 2WD Amigo : Flamigo smile
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6212 MB (Peak: 0.7249 MB) Data Comp: Off Server Time: 2026-06-07 07:03:13 UTC
