What is the best way to clean the EGR valve? #630855 07/28/05 04:48 AM
W
WashingtonKevin Offline OP
I have a 93 V6 running a little rich and hesitating some under acceleration.
I am open to other things to check. Cap and rotor and plugs and wires and fuel filter are ok. No obvious vacuum leaks in intake / maf.
Thanks,
Kevin
on the other hand, I just rebuilt the rear end after the outer pinion bearing let go and all is well again. I am on a short tune up craze here.
Re: What is the best way to clean the EGR valve? [Re: WashingtonKevin] #630856 07/28/05 05:28 AM
4Crawler Offline
I used a gun cleaning kit and gun cleaning solvent to clean mine. Small round brushes can get into much of the valve and then spend and afternoon filling the valve w/ solvent, let it sit for an hour or so, dump out and refill. Also clean any modulators, VSVs and hardlines feeding the EGR.
Re: What is the best way to clean the EGR valve? [Re: 4Crawler] #630857 07/28/05 01:28 PM
W
Roger,
Thank you for your time. I will give that a go.
Kevin
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5929 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-10-24 02:34:14 UTC
