getting through firewall
#631093
07/28/05 10:26 PM
How do I get a wire through the firewall on a 95 toyota 4runner?? (its for a switch for off road lights.)
1995 4runner SR5 PP rear springs Hella FF1000 lights 31X10.5-15 Nokian Vativas <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: getting through firewall
[Re: Davis5210]
#631094
07/28/05 11:07 PM
There are numerous locations on the firewall that wires currently pass thru that have rubber grommets surrounding them that are fitted into the holes.I have a 95 4rr and I believe I ran mine thru a hole that is located undeer the console on the drivers side
Russ Toyx4 IN the Toy world <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED Happy trails to you (1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear (2)95 4Runner All Pro Nerf bars BFG 32s ARB bull bar Downey 2" rear coils Downey headers (3) 90 Montero LWB 3.0 auto (4) 98 Kawi GPZ1100
[Re: 4xmonty]
#631095
07/29/05 02:46 AM
how do you get the rubber grommets off?? do they just pop out??
[Re: Davis5210]
#631096
07/29/05 02:54 AM
I went through the passenger side. I used a small phillips head screwdriver and just poked a hole in the grommett, ran the wire through, then put RTV sealant on the grommet to make sure it didn't leak.
#631097
07/29/05 09:42 PM
I went through the passenger side. I used a small phillips head screwdriver and just poked a hole in the grommett, ran the wire through, then put RTV sealant on the grommet to make sure it didn't leak. I second that thats how I did it too <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> Russ (Toyx4)
[Re: 4xmonty]
#631098
07/30/05 03:14 PM
nice <img src="/forums/images/graemlins/cheers.gif" alt="" /> thaks a lot
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6094 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-17 13:01:20 UTCValid HTML 5 and Valid CSS
