Going to the yards #631282 07/29/05 01:59 PM
Madcat Offline OP
OK guys and gals in 3 weeks I'm heading off to the local boneyards for some scavenging, if any of you needs anything let me know and I'll try to get whatever I can. There are mainly Troopers, a couple of Amigos and a handful of PUPs and Rodeos. Just so you know I am NOT looking to make any profit off of this just trying to help any of you guys get some junk.
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Going to the yards [Re: Madcat] #631283 07/29/05 03:58 PM
TrooperJ Offline
Id be up for any AISIN manuals you find.
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Going to the yards [Re: TrooperJ] #631284 07/29/05 05:52 PM
Starchild Offline
Becoming a hub broker, are we? <img src="/forums/images/graemlins/smile.gif" alt="" />
Last time I checked, you only had one Isuzu, right?
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Going to the yards [Re: Starchild] #631285 07/29/05 06:09 PM
TrooperJ Offline
Something wrong with that? <img src="/forums/images/graemlins/pfft.gif" alt="" /> I dont know why, i just like to rebuild the things. Its easy, and you can make a small penny off of em. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
-J (sharing the wealth)
Re: Going to the yards [Re: TrooperJ] #631286 07/29/05 06:12 PM
Starchild Offline
No problem here <img src="/forums/images/graemlins/smile.gif" alt="" />
Just messing with ya <img src="/forums/images/graemlins/nana.gif" alt="" />
"SERENITY NOW!"
Re: Going to the yards [Re: Madcat] #631287 07/29/05 07:51 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
I could really use a driver-side headlight support bracket for my 98 Rodeo. Me and ABS don't get along, so I threw the fuse in the trash, but in the meantime, had to get a new fender, put my ARB bumper on there instead of the stock one (I guess that's a good trade) and have to replace the grille and the headlight support bracket.
Anyway, the grille I might just do without -- but even if I get one, sourcing it locally will be a better idea... But the headlight bracket, that'll do just fine.
Basically what I'm referring to is a rectangle-shaped honeycomb piece of plastic that positions the headlight -- not the headlight itself, just the plastic piece behind it. My headlight is fine, but when I hit the guardrail the light got pushed back and shattered the bracket.
Should only be a coupla bucks, but around here they won't sell it to me without the headlight (and we don't have any pick-n-pulls locally).
Anyway, let me know what you find, and I'll let you know if I find something before then...
-Chris
P.S. I'll PM you my phone number so you can call the day you're going and see if I still need it, just in case I'm not around on-line for a few days...
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: Going to the yards [Re: Chris Perosi] #631288 08/01/05 02:08 PM
Madcat Offline OP
Come on guys, I gave ya'll 3 weeks to come up with your wish lists.
Re: Going to the yards [Re: Madcat] #631289 08/07/05 01:54 AM
As it stands now, I'm definitely gonna need that support bracket. It's a little plastic piece that bolts to the front of the sheet metal right behind the headlight, and the headlight adjustor screws bolt into it so you can aim it. It's like 3 or 4 bolts into the sheet metal, and it's about the same size and shape as the trim around the front of the headlight.
Rather than keep describing it, I'll make it easy. It's the rectangle-shaped un-numbered part just below the "adjustor screw" (10 in the picture) at the far right of the pic...
Let me know if you can make it happen. I don't know if there's a difference between this piece on the 98/99 models vs. the later model Rodeo with the non-square headlights, but if the best you can do is a 2004 or something, get it anyway and send it my way, I'll make it work if it's a different shape...
I think I mentioned it already but it's the driver's side headlight...
Thanks again,
Chris
Chris Perosi
OutdoorWire, Inc.
Re: Going to the yards [Re: Chris Perosi] #631290 08/07/05 02:08 PM
I
islandracer Offline
I could really use some interior pieces for my '91 P-up:
1. Power window reg/motor (driver and pass side)
2. All inner door handles (door panels would be nice but may kill me on shipping).
TIA!
Shoootz!
Ton
B.Y.E. ~ Back Yard Engineering
Re: Going to the yards [Re: Chris Perosi] #631291 08/07/05 02:16 PM
Madcat Offline OP
Thanks again,
Chris
That helps out alot I'll see what I can do,
'91 P-up:
One of the yards has plenty of these trucks, any preferred color?
I also think that 1 or 2 of those PUPs is diesel so if there is any interest I'll look closer.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6399 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-11-02 12:32:56 UTC
