1990 2.8LV6 A/C idle control? #631312 07/29/05 03:41 PM
greauxpete Offline OP
What controls the A/C idle control speed? Isnt there a switch that increases the idle when the A/C is on?
If so, where is it?
I dont think my truck is ideling fast enough
when stopped and in "Drive" such as at stop lights. My A/C compressor kicks off, but if i give it some gas and increase
the RPM's it will kick back on.
Also, where do i ramp up the "global" idle speed?
Where is the idle air control valve?
1990 Isuzu Trooper 2.8L V6
Re: 1990 2.8LV6 A/C idle control? [Re: greauxpete] #631313 07/29/05 11:21 PM
CPOM Offline
IAC valve is the valve that sticks out at 3:00 looking down at the engine. It is a pintle with a rotating stepper motor that retracts allowing air to go around the throttle blades.
The Idle air control is set through a procedure you can find here:
POST.........
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5884 MB (Peak: 0.6365 MB) Data Comp: Off Server Time: 2026-06-09 23:07:13 UTC
