Sticky lock switch. #631333 07/29/05 04:32 PM
E
elnido Offline OP
My driver's (only) door lock won't commit to one position or another with the power door lock button. It seems to get hung up in the middle. I've tried "exercising" it manually to clean it out. No effect. The "action" feels normal when I switch it manually from the inside door "nub" above the handle.
This happend a few months ago and corrected it's self over the course of a couple weeks. Now it's back. Maybe it's the humidity? Is this easy to fix?
Thanks for input.
95 T100 SR5
Re: Sticky lock switch. [Re: elnido] #631334 07/29/05 05:03 PM
4
4xGeek Offline
Sounds like the actuator is getting tired... Mine did about 2 years ago - still haven't gotten around to replacing it. Cheap & relatively easy to do however. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Sticky lock switch. [Re: 4xGeek] #631335 07/31/05 05:43 AM
Jake97T Offline
My drivers door actuator does the same thing periodically, its worse in the winter time...where can you buy an actuator that will fit the stock assy???
Re: Sticky lock switch. [Re: Jake97T] #631336 07/31/05 07:25 PM
4
4xGeek Offline
Just about any audio shop will have 'em...
4xGeek (Chris)
Re: Sticky lock switch. [Re: 4xGeek] #631337 09/17/05 12:44 AM
Jake97T Offline
Not only is my door lock not commiting to being locked or unlocked, the lever on the inside of the door will not move without using the key, whats up with that???
Re: Sticky lock switch. [Re: Jake97T] #631338 09/17/05 02:00 AM
kewlynx Offline
Sounds like you've got some binding going on; might have some plastic parts in there.
Go to the dealer and have them pull up a parts breakdown to see if you can figure it out from there.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6779 MB) Data Comp: Off Server Time: 2026-06-07 09:29:47 UTC
