oil pan gasket 3.2 rodeo 97 #632310 08/01/05 09:52 PM
snowrodeo Offline OP
ok i'm having trouble with figuring out the search feature: first how would i enter a search for oil pan gasket changing on my rodeo and what time frame would i use? second, can i change it without having to drop the front axle? any tricks to watch out for? i do kow it's just black RTV, no gasket.
TIA
97Rodeo Rancho9ks/Aisins/3.2L SOHC/M1 only
Proper Prior Planning Prevents P*ss-Poor Performance--Maj. R.T.Spooner USMC(Ret.)
Re: oil pan gasket 3.2 rodeo 97 [Re: snowrodeo] #632311 08/02/05 05:31 AM
rubo Offline
Talking about time frame is simply absurd.
Consider spending at least full day if you have prior experience, air tools & a friend. Or it will take you forever.
There is no gasket. It comes on a silicon from factory.
I wouldn't use black silicon. I would go with either the red (hight temp) or a grey (preffered in this case).
Also, i would change at least the rear seal at the same time (if not the front also). Not sure on the '97, but on '98 & up you have to pull the tranny to be able to take the pan down (by pulling the tranny i mean seoarate it from the engine, not take it off the truck).
And no, there is no way you will be able to do it without removing the diff.
Good luck.
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: oil pan gasket 3.2 rodeo 97 [Re: rubo] #632312 08/03/05 07:03 AM
trooperbc Offline
rubo says
uh-h-h-h, i think he's talking about the time frame to use in the search function.... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
snowrodeo writes
try
+oil +pan +gasket
also
+oil +pan +gasket +rodeo
time frame? experiment. i always get it wrong the first time i try.
also see
how to search forum?
good luck
Re: oil pan gasket 3.2 rodeo 97 [Re: trooperbc] #632313 08/08/05 06:42 AM
you're right, i was trying to figure out time frame to use in the search. i had it figured out a few months ago but lost the "groove" from not logging in often enough. let this be a lesson to the unfaiththful! <img src="/forums/images/graemlins/evil.gif" alt="" /> at this point i haven't mustered the energy to start the project. are rear seals possible to do without pulling the trans right out of the truck? tia
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6017 MB (Peak: 0.6587 MB) Data Comp: Off Server Time: 2026-07-17 04:37:20 UTC
