W56 from T100 exactly the same as W56 in Tacoma and Hilux Pickup?
#632705
08/03/05 03:32 AM
I have a 95 T100 2.7L 4Cyl 2wd. There is a seal at the tailshaft on the transmission where theh driveshaft goes into. Mine is leaking and I went to replace it, and the seat that the seal presses into was all scratched up (i think from the seal puller when I pulled the old seal out). I replaced the seal but it still leaks. So, I guess I'm going to have to call around and find a used W56. So my question is, is the W56 from the T100 exactly the same as the W56 used in the Tacoma and Hilux Pickup? If I got a W56 from a Tacoma or Hilux, would it just bolt right in?
Re: W56 from T100 exactly the same as W56 in Tacoma and Hilux Pickup?
[Re: Squeezer99]
#632706
08/03/05 09:56 AM
short answer is no! input shafts are different on the older mini trucks and rear of tranny is different on tacomas, because of the different t-cases.
cheers
[Re: Squeezer99]
#632707
08/03/05 03:37 PM
Are you sure it's W56? My "96 T has the W59 Trans. Just a thought...
joel
*1996 T100 2wd,long bed w/5speed Borla Cat-back *2002 Z28 Convertible *2002 Lightning *2005 Trailblazer
[Re: jabush]
#632708
08/03/05 07:47 PM
Are you sure it's W56? My "96 T has the W59 Trans. Just a thought... according to the 1995 toyota factory service manual, my truck has the w56.
[Re: Squeezer99]
#632709
08/06/05 12:25 AM
I've seen a hurst short throw shifter for Tacos would it work on my 97? It's a five speed with a 3.4 <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6688 MB) Data Comp: Off Server Time: 2026-05-29 22:16:44 UTCValid HTML 5 and Valid CSS
