Brake Pad Sensors on '02 Trooper?? #634523 08/08/05 08:21 PM
P
parkstribe Offline OP
Hi,
Does anybody know if there are front brake bad sensors that will squeal on an '02 Trooper when the brake pads are worn out? Thanks in advance ... Fred.
Re: Brake Pad Sensors on '02 Trooper?? [Re: parkstribe] #634524 08/08/05 11:52 PM
JLEMOND Offline
THEY ARE NOT REALLY SENSORS IN THE TRUE TERM AS IN ELECTRICAL SENSOR , BUT THEY ARE SQUEELERS ON EACH INSIDE BRAKE PAD THAT RUBS AGAINST THE ROTOR WHEN THE PADS WEAR OUT, THEY ARE PART OF THE METAL SHIM THAT GOES IN BEFORE THE PADS GO ON ,USUALLY WHICH ARE LEFT OUT ON AFTERMARKET PADS , SAME DESIGN AS ON THE REAR JERRY
Re: Brake Pad Sensors on '02 Trooper?? [Re: JLEMOND] #634525 08/09/05 08:48 PM
P
Thanks Jerry. You are THE MAN as usual!! I wanted to know that I'll hear the squeel if/when the pads get thinned to that point. Thanks again ... Fred.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5917 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-06-07 02:21:55 UTC
