No blink, blink action.
#634919
08/10/05 02:20 AM
I let my brother borrow my 89 LWB while he was doing his internship at Houston. He brought it back in fairly good condition, except for the blinkers; they wonÆt blink. He said the problem started after he used the hazard lights.
HereÆs the problem. When I turn on the hazard light only the right front light will blink and both of the rear ones. The left blinking light will not turn on. Whenever I put the turn signal either left or right I get no blinking action at all. I have replaced both of the front light bulbs along with the flasher near the pedals and I still have the same problem.
What else can I check/replace to get my turn signals to work? ItÆs really annoying to use the hand as a turning signal.
1989 Mitsubishi Montero LWB, Superwinch Manual Hubs
Re: No blink, blink action.
[Re: hotdogx3]
#634920
08/10/05 02:41 AM
I had the same issue on mine. Turns out the wires going to my hitch had burned up against the tailpipe and my front turnsignal had one of the common grounds pulled out of the plastic casing.
Mine was the the right and if I turned on the hazards I either got only the left or it would work for 5-10 seconds and blow the fuse.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
[Re: juggernaut]
#634921
08/11/05 01:14 AM
Thank for the response. I'll inspect my lights tonight and hopefully get them to work.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5921 MB (Peak: 0.6455 MB) Data Comp: Off Server Time: 2026-06-21 10:03:13 UTCValid HTML 5 and Valid CSS
