Seatbelt Won't Release ( Not a seatbelt return problem )
#635187
08/10/05 09:24 PM
I have been reading this post for quite a while and have not seen this problem before. When I go to put my seatbelt on it will not release unless I play around with it for awhile by gently tugging or hitting the side panel where the mechanism is. If I do get to put the seatblt on it usally stays tight and I can,t even lean forward. I have removed the seatbelt assembly and do not see anthing that can be repaired. Any suggestions? I have seen the 100K warranty mentioned fot the return problem. Would this apply also. I am presently at 85K.
Re: Seatbelt Won't Release ( Not a seatbelt return problem )
[Re: yorkt]
#635188
08/10/05 09:57 PM
I have the same intermittent problem on my truck
1997 T100 SR5, X-Cab, V-6, Auto, 113,000 miles, Bilstein shocks
[Re: yorkt]
#635189
08/10/05 10:23 PM
I had the same problem with my drivers side seatbelt. I took it apart, ane tried to see what the problem was. My conclusion was that there is a device inside the seatbelt mechanism that determines if the seat belt is in an upright position (level). If the seat belt is at all under stress (i.e. in the case of sudden crash)and the seatbelt mechanism isn't level, this device prevents the seatbelt from disengaging an giving more slack.
If you re-adjust the bolt that keep the seatbelt attached (the one at the bottom as you attach it the door frame) so that it is level, and you also make sure that the hook at the top of the seatbelt is in the right position, it should allow the device to stay level.
This is my theory anyway. Of coarse it didn't work for me because the same time I tried to fix this problem I also performed the "minute mod" and this totally kyboshed my seatbelt spring. I had to order a new one ($180 Can. <img src="/forums/images/graemlins/frown.gif" alt="" />)
#635190
08/11/05 03:03 PM
Well I put everything back together and it works for now. I did not see any way to keep the mechanism level. When the bottom bolt is tightened everthing is locked in place. Hopefully the problem does not return for awhile.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5969 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-10 07:27:21 UTCValid HTML 5 and Valid CSS
