grease lower balljoint-D30 #635217 08/10/05 11:07 PM
bhartwell59 Offline OP
hi all,
there doesn't look to be a zerk fitting to grease the lower ball joint on a dana 30.
does that mean it'll never need to be?
-b
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: grease lower balljoint-D30 [Re: bhartwell59] #635218 08/10/05 11:58 PM
BigJim Offline
It means the factory in there wisdom thinks it will last till a warranty is over! YES it will wear out! When it does getcha a nice MOOG with a zerk. Then you can squirt all the greease in it you would like. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: grease lower balljoint-D30 [Re: BigJim] #635219 08/11/05 07:18 PM
yea an if you do not have an air
hammer or press, you better have
some smarts with a piece of pipe
an BFH. an lots of beer.
Re: grease lower balljoint-D30 [Re: bhartwell59] #635220 08/12/05 12:43 AM
JeePete Offline
You could install a zerk and grease it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5957 MB (Peak: 0.6533 MB) Data Comp: Off Server Time: 2026-11-02 21:47:12 UTC
