89 Trooper Tune Up #635339 08/11/05 06:26 AM
thecure7 Offline OP
What all should be done, checked, and what plugs/wires do you guys recommend?
I plan on:
Plugs
Wires
Cap and Rotor
What else would you guys do? My Troop has 157K and not sure of the last time it was tuned up. Any Tips to make the plug change and anything else easier? What Gap for plugs, etc?
Thanks. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
1992 Land Rover Range Rover 3.9L V8
1995 Honda Passport V6 4x4
1989 Isuzu Trooper 2.8L V6 Manual ~Sold
Re: 89 Trooper Tune Up [Re: thecure7] #635340 08/11/05 01:37 PM
1
1jackleg Offline
I used AC delco plugs, factory heat range. The rotor and cap came from napa as did the plug wire set. I bought the highest quality set they offered. If you have a napa close by, I can post up the part numbers and prices for you if you would like. HTH - JL <img src="/forums/images/graemlins/patriot.gif" alt="" />
Oh yeah - I believe the plug gap is 0.045", but cannot remember for sure. I'll have to look it up in the manual tonight.
I ain't real bright...
1990 Trooper LS, V6, Auto, 4door
132,000 miles 11/26/09
Re: 89 Trooper Tune Up [Re: 1jackleg] #635341 08/11/05 05:08 PM
maxwell417 Offline
Change the O2 sensor while you are at it.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 89 Trooper Tune Up [Re: thecure7] #635342 08/11/05 09:37 PM
RT1 Offline
What engine?
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: 89 Trooper Tune Up [Re: RT1] #635343 08/12/05 02:06 AM
thecure7 Offline OP
What engine?
It is the 2.8 and I just got through doing the cap, rotor, wires, and plugs, as well as fixing a vacuum line and that took care of my sputtering problem. Thanks for the input guys!
Re: 89 Trooper Tune Up [Re: thecure7] #635344 08/12/05 12:07 PM
1
1jackleg Offline
excellent. glad to hear everything is back to normal. - JL
Re: 89 Trooper Tune Up [Re: 1jackleg] #635345 08/12/05 02:29 PM
thecure7 Offline OP
by the way, all my plugs were gapped at .050. I gapped the new plugs to .045, and auto zone told me .044. Anyway, don't know what was up with the orignal plugs like that.
Re: 89 Trooper Tune Up [Re: thecure7] #635346 08/12/05 03:48 PM
1
1jackleg Offline
could have been electrode wear. at any rate, excessive gap causes issues for sure, more energy to bridge the gap.
What color were they? White scale? Light brown?....JL
Re: 89 Trooper Tune Up [Re: 1jackleg] #635347 08/12/05 04:00 PM
thecure7 Offline OP
light brown to a small amount of dark brown. Pretty corroded electrode's that were a little white to alot light brown. My rotor was just about black and there was a ton of corrosion on the coil top under the wire. I cleaned and put that plug wire grease on all the tops before reinstalling the new wires.
What is the easiest way to check the timing on these trucks, do you know? ONEBADTROOPER thinks this is what might be causing my high idle.
Re: 89 Trooper Tune Up [Re: thecure7] #635348 08/12/05 05:02 PM
1
1jackleg Offline
sorry, don't know right off. I would have to look it up in the helms manual. I need to check mine also, but the truck is running real good and I don't think the timing is off.
I could get the procedure for you tomorrow if you would like.
Jackleg
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6443 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-05-29 18:56:15 UTC
