Page 3 of 3 1 2 3
Re: How many have done the 4.3 conversion? [Re: BobShaw] #635903 08/24/05 09:08 PM
Mendel Offline
Anyone ever try to get an engine from one of these?
GMC Typhoon (Turbo 4.3, 280 hp)
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: How many have done the 4.3 conversion? [Re: Mendel] #635904 08/24/05 09:52 PM
LandRaider Offline
I put a 4.3 in to get away from high rpm power, and hoses, and pipes, and intercoolers, and junk everywhere.
Believe me!! I think turbos are cool.... just not in a 4wd truck.
I have had both.. I like low end grunt.
Re: How many have done the 4.3 conversion? [Re: LandRaider] #635905 08/25/05 02:58 PM
Speaking of 4.3 swaps, anybody know how Don's is coming along?
Re: How many have done the 4.3 conversion? [Re: MontyMcV] #635906 08/26/05 05:38 AM
don Offline
Wiring succesfully blended.
With the fuel pump unpowered, I turned the key and cranked the engine, the alternator light works, the oil press light work. Heck, even the headlights work (custom wiring there too).
It's got PHIL's "ol betsy"'s V6 gauge cluster and looks like it's showing everything in the correct places.
Front diff is now a V6 diff with an RD110 inside. Tomorrow I'll test the compressor and lockers switches.
33x12.5's are on.
Waiting on the custom rad, and still need to order the driveshafts.
...nearly there, looks good.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: How many have done the 4.3 conversion? [Re: don] #635907 08/26/05 02:35 PM
Wow, you've come far. Way to go! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: How many have done the 4.3 conversion? [Re: don] #635908 08/26/05 03:32 PM
LandRaider Offline
SO you did the 4clinder fuel guage in the v6 cluster Kary special trick huh?? Awesome Don!!
Whats the ETA?
Howabout that shifter?? working good?? firm and positive, or sloppy like mine??
Re: How many have done the 4.3 conversion? [Re: LandRaider] #635909 08/27/05 04:23 AM
don Offline
ETA?
Well, my boss wants me back at my desk after next week...
Yes, the fuel gauge "trick" was done!
The 4 cyl and 6 cyl gauges were "blended" to take advantage of both, but mostly it's the 6 cyl gauges (eg, it uses the Hi-Beam light under the tach).
There were many wrinkles that the Docter hadn't encountered especially as his was/is M/T, and mine was/in A/T.
Shifter is the stock Mitsu A/T lever, with the linkage modified and greatly simplified and "adjusted" to make it mechanically shift all 4 forward gears on the 4L60E.
Felt quite firm and precise when I last checked it!
A lot of time, math, metal fab skills, advice, and good old fashioned trial and error made it possible.
A LOT of time poured into it so far.\
...Oh yeah.
My 2.6 was sold locally, and is currently on the road making another driver very happy! Good re-build with a lotta miles still in `er.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6281 MB (Peak: 0.7192 MB) Data Comp: Off Server Time: 2026-06-07 05:45:53 UTC
