glowplug controller and fuel filter assembily on the c223 #636095 08/13/05 09:09 PM
modern_cowboy Offline OP
Allrighty!, where to start.... im doing a c223 conversion into a s10.... i have most the harness and controller fuel filter etc from the c223. ive completely eliminated everything engine related from the s10 no computer no insterment cluster, i'll be using all aftermarket gauages... but can i get a detailed explination of how the glow plug controler works? inputs and outputs, and how the fuel filter/water seperator works.... so i can wire in indicator lights that would have come from these units....
currently im started body work and i have the engine on the chassis.... but im not far off from diving into electrical work! any halps appreciated!!!
2002 3.9L dodge dokota 2x4 <img src="/forums/images/graemlins/frown.gif" alt="" />
and one C223... so far <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: glowplug controller and fuel filter assembily on the c223 [Re: modern_cowboy] #636096 08/23/05 10:11 PM
TX76513 Offline
If you PM me your address (or fax number) I can send you the wiring diagram for the 223. In regards to the water fuel seperator - trash it and just convert to a standard fuel filter.
86 Isuzu Trooper TD 5 speed
82 Isuzu Diesel I-Mark
86 300 SDL MB 126
85 300SD MB 126
82 300 D MB 123
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5875 MB (Peak: 0.6357 MB) Data Comp: Off Server Time: 2026-07-17 00:46:19 UTC
