used weber #636596 08/15/05 02:32 AM
juggernaut Offline OP
Hello again. I got my hands on a used weber carb off a 2.6 standard but need some instructions or tips how to get it on mine. Is there a write up somewhere. These vacuum lines are giving me a headache.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: used weber [Re: juggernaut] #636597 08/15/05 04:00 AM
W
wyleone Offline
First, which weber is it? You can go to <a href="www.carbs.net" target="_blank">Carbs.net</a> or <a href="www.redlineweber.com" target="_blank">RedlineWeber</a> to ID it. It could be a 32/36 DFV, 32/36 DGV, or 38 dgas. BTW there will be one vaccume hose hooked to the Weber and that will be the Vacc advance to the carb, all the rest are obsolete, including the ECU under the blower motor under the passenger dash. <img src="/forums/images/graemlins/notooth.gif" alt="" />
You will need the Redline adapter plate to mount the Weber to the mitsu intake. You will also need the throttle cable bracket to move it over on the valve cover.
Re: used weber [Re: wyleone] #636598 08/15/05 04:04 AM
Chris_J Offline
The 2.6 Mikuni works really well when it works. And mine is working well. The vacume lines on that thing on the other hand. <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: used weber [Re: juggernaut] #636599 08/15/05 05:09 AM
Got some pics of carb over here. Not there right nowto check which one.. Gotta get it off before the critters move in.
http://catocom.com/forum/showthread.php?t=1558
Re: used weber [Re: juggernaut] #636600 08/15/05 05:20 AM
W
wyleone Offline
That's a 38 dgas. It tends to create more low end power and less gas milage. Both barrels open evenly, unlike the other two I mensioned. If you end up not wanting it, let me know what you want for it. I would like to have it for myself. <img src="/forums/images/graemlins/smile.gif" alt="" />
I see how the throttle cable attached to the valve cover, you want the whole bracket and the plate that says Redline on it at the base of the carb. Lucky dog. If you do not want any of it I am interested. I know a guy that needs the throttle bracket. That is a Thorly exaust header and a new fan clutch too. Somebody hit a goldmine <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: used weber [Re: wyleone] #636601 08/15/05 05:36 AM
My Dad went a little crazy when he saw my Raider and purchased the other 3. That Blue one donated it wheels and bumper to mine.
We haved gutted the interior and put it in his camo one. The red one has the engine in pieces behind it but the interior is intact. Dad wants to do a frame up with the blue one and put the red body on it.
Course he is still looking for the parts for a turbo conversion. The blue engine turns over but doesnt start course it is missing alot of electrical components
Re: used weber [Re: juggernaut] #636602 08/15/05 05:41 AM
W
wyleone Offline
I just had to put an igniter in mine this weekend. $110 for a part smaller than my thumb. <img src="/forums/images/graemlins/barf.gif" alt="" /> If you have any questions just ask. There are others here with them too. Carbs.net is a retailer for Redline weber and you can get jets gaskets, fuel cutoff solinoids choke parts ect from them, as well as snorkel adapters. I bought the K&N model adapter and run a Dakota airbox setup instead of the open filter (mud catcher). I'm very interested in what you think of the performance when you get it on.
Re: used weber [Re: wyleone] #636603 08/15/05 07:18 AM
52degrees Offline
Why are you guys throwing so much money at old bbqs?
My gas grill is so much nicer. A lot closer to state of the art, too. No choke, er, vents to open or close or anything. And cooking with gas is so much more precise.
I'm sure there will always be those die-hards out there who say that gas just doesn't have the flavor of charcoal, but I disagree.
And gas pollutes the air far less than charcoal.
And yes, this was all written as an equivoque. <img src="/forums/images/graemlins/smile.gif" alt="" />
Clay
KG6VNX
Re: used weber [Re: 52degrees] #636604 08/15/05 04:07 PM
W
wyleone Offline
My charcoal is my daily cooker and I don't have the time or $$ to swap for a gas grill. The easiest way to get a gas grille is to go buy a Rubicon gas grille huh, no down time. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: used weber [Re: wyleone] #636605 08/18/05 06:33 PM
Is there an aftermarket that will pass emissions? My Dad wants to get rid of his carb. He isnt looking for preformance. He was in Corpus and someone mention a conversion where you switch intake manifold and it will still be legal.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6403 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-05-30 01:06:25 UTC
