quick ARB locker/5.29 gears questions #637698 08/17/05 05:10 AM
DanWheeler Offline OP
Just wanted to confirm that ARB only makes the front locker (the RD110) for the 8" front IFS (on the Gen1 V6)
and the rear 8" for a Gen1 is a slam dunk with the RD05 correct?
So for a gen1 4 cyl to be ARB locked front and rear you need
- 1 ARB RD110,
- 1 ARB RD05
- 1 ARB compressor
- 1 V6 8" front axle installed
and gear ratios dont matter as long as the ring gear size is correct - so a pair (front/rear) of 8" 5.29 gears from frank would fit in with all this right?
thanks,
dan
Re: quick ARB locker/5.29 gears questions [Re: DanWheeler] #637699 08/17/05 07:01 AM
CapnCrunch Offline
I did all these on my '88 (well worth it), except I still have to install the 5.29 gears (they're sitting in my garage). Your info is correct, but not complete, unless you're willing to gamble.
For the 8" rear you'd need the ARB RD05 and one carrier bearing as one should come with the ARB kit. For installing the ring and pinion in the rear it's highly advisable to replace the associated hardware (shims, bearings, seals, etc...mainly pinion-related parts).
Same goes for the front...good idea to replace the associated pinion hardware AND ADDITIONALLY the rest of the diff hardware (bearings, shims, seals, etc) especially since (my guess is that) you got the front Gen I V6 diff from a junker (no idea of it's history). An ARB RD110 goes in the front.
Here's where it gets abstract: others who have done this swap have had to do very minor mods to the mounts. Mine was pretty much a bolt-in...took some effort but it bolted in with only a little pounding down of the cross-member. Also, another person had to shorten their front drive shaft by .75 inches. Yet another person had to shorten theirs by .8 inches. Mine had to be shortened by an inch and a half (twice as much).
The 5.29 gears are part number MB241981 for both the front set and the rear set if you put the Gen I V6 front diff into the 4-cyl Gen I with the 8" rear (front and rear both 8"). If you're ready for the diff swap and the locker installs right away and can't wait for the 5.29 gears to arrive (takes a couple or three months to receive them once paid for) make sure your front and rear ratios are the same. Odds are that they are the same, but if in doubt, in the V6 front diff going in, count the number of teeth on the ring gear and divide that number by the number of teeth on the pinion (i.e., 37 teeth on the ring gear ¸ by 8 teeth on the pinion gear = 4.625 diff gear ratio). Compare the sum with with your ratio (as indicated on your engine-bay data plate). 5.29's (5.2857143) are 37 ring gear and 7 pinion gear teeth.
Going with dual ARB's is a big BIG BIG improvement in traction. A couple Sunday's ago EmptyVengeance (in his new Jeep) and I went wheeling on a couple trails with some very steep terrain on somewhat loose dirt. I started up this one long section with just the rear locker engaged and found that, although I was continuing with forward/upward momentum, I was still losing some traction. Once I kicked in the front locker as well I crawled right up it like I was spider-man. In Moab this year (my hurry for doing the front locker and not waiting for the gears to arrive) I couldn't believe the amount of traction I had. On the Kane Creek trail, historically I would struggle to get past the easiest part on the hardest mandatory obstacle of that trail. This year I walked right through the hardest part of that obstacle like it was just a minor bump in the road. The difference is night and day.
If you can, and when they're available again, I'd highly suggest a set of Mark Hardman's t-case gears as well. Those combined with a set of 5.29's will almost double your crawl ratio.
Hope your mods go well. If you wheel your rig, the mods you're planning will be well worth it.
EDIT: Forgot to mention...you'll need the Gen I V6 front axles for that diff swap. The axles that go with the 7.25" (old 4-cyl) front diff won't fit the V6 diff. They'll fit the hubs fine though (get new cir-clips for the axle-ends). What I did was take the old axles that I got with the V6 diff front diff and had them rebuilt.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: quick ARB locker/5.29 gears questions [Re: CapnCrunch] #637700 08/17/05 08:05 AM
Spiderman! Thats what I'm talkin about.
Thanks for the info Cap'n. I may be ramping up for some fun winter car/truck projects once I sell my money-sucking car so trying to get some ducks in a row.
My buddy just caught the bug with his Cherokee and my other friend inherited a Rubicon Wrangler so now I have to play catch up <img src="/forums/images/graemlins/frown.gif" alt="" /> / smile
yes, would love to get the transfer case gears eventually as well. I figure if I lock it front and rear, get the 5.29s and some 33s I'll be happy for a while.
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: quick ARB locker/5.29 gears questions [Re: DanWheeler] #637701 08/17/05 08:16 AM
CapnCrunch Offline
Yeah, running 33's with a 2.6 pretty-much demands having 5.29 gears. At present, I'm running 33's on the stock 4.625's on my 2.6 and it's a very painful experience on even the slightest uphill climb on the highway. <img src="/forums/images/graemlins/scared.gif" alt="" /> Great on the trail but patience is a requirement on the highway. It's a good thing it's not my daily driver. And so far I've mostly towed it to trailheads to go wheeling. That'll change once I get the gears installed.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: quick ARB locker/5.29 gears questions [Re: CapnCrunch] #637702 08/17/05 11:32 AM
Chris_J Offline
CapnCrunch, you say its bad on uphills? Like slight inclines? Or like severe mountains? Most hills around here are about 20 degree incline at the most how bad would it be if I ran 33s on that I also have the 2.6 and stock gearing. Im running 30s right now debating between 32s and 33s can't figure it out. let me know.
Re: quick ARB locker/5.29 gears questions [Re: Chris_J] #637703 08/18/05 12:50 AM
CapnCrunch Offline
Even the slightest up-slope begins to task it.
My guess is that you should probably be okay, considering that the altitude where I drive on a daily basis ranges between 5200 feet and 7500 feet. The altitude is what really kills me. When I was in Moab at the end of May the drop in altitude was very noticeable to me...was quite a bit easier driving on the highway.
Nevertheless, you will definitely notice a difference in performance going from 30's to 33's. At your altitude, though, I would imagine it wouldn't be near as painful for you.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: quick ARB locker/5.29 gears questions [Re: CapnCrunch] #637704 08/18/05 01:02 AM
Chris_J Offline
Im thinking 32s.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6257 MB (Peak: 0.7219 MB) Data Comp: Off Server Time: 2026-11-16 01:32:17 UTC
