Iridium spark Plugs pros/cons #638771 08/20/05 06:22 AM
J94_4runner Offline OP
Has anyone personally used these things? Denso makes them for like $8? each. I was going to change the plugs on my girlfriend's mom's Lexus RX300 and when I pulled the 1st plug noticed they were Denso Iridiums & looked like new at 75K. I'm currnetly using NGK V grooves for about $2each and change them about every 15K. My brother is thinking about putting a set in his LS1 Trans am. changing plugs in that car SUCKS. So, anyone know anything about them?
www.celicasupra.com
Re: Iridium spark Plugs pros/cons [Re: J94_4runner] #638772 08/20/05 10:14 AM
4
4mudder Offline
Ive got them now and theyre not bad at all but theyre more expensive here like 14.00 ea. I say go with them they aint gonna do any harm and they last like 60k.
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: Iridium spark Plugs pros/cons [Re: 4mudder] #638773 08/20/05 05:15 PM
D-runner Offline
Been thinking about going to the Iridium plugs too. My father has them in his jeep and it made no difference. Just recently read a post on Pirate about the Iridium plugs and BlueCoyote3 was talking about using the double electrode plugs used in the 5vzfe (3.4 Taco motor). They fit the 22r/re with no issues. What makes them 'good' is that the spark kernal is out in the open, not hidden behind the electrode and they are only $1.69 at Autozone.
Part #'s are:
NGK BKR5EKB
Denso K16TR11
I may try this and see how well it works.
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Re: Iridium spark Plugs pros/cons [Re: D-runner] #638774 08/20/05 06:28 PM
kyle-22r Offline
i've thought of trying those taco plugs as well. i wonder how one gaps them?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Iridium spark Plugs pros/cons [Re: kyle-22r] #638775 08/20/05 07:13 PM
I replaced the plugs on my girls 3.4. weird looking NGK plug. I think I'm just gonna stick to my NGK Vgroove 1 colder for my 3.0.
www.celicasupra.com
Re: Iridium spark Plugs pros/cons [Re: J94_4runner] #638776 08/20/05 11:50 PM
willzrunna96 Offline
iriduims are usueally 12 or 13 are you sure there not denso or ngk platinums?
Re: Iridium spark Plugs pros/cons [Re: willzrunna96] #638777 08/21/05 01:12 AM
i thought they were $8each but guess they're more. Screw it, i'm gonna stick to NGK's. I'll tell my brother only pro is longer change interval. for him it makes a difference, for me it doesn't.
www.celicasupra.com
Re: Iridium spark Plugs pros/cons [Re: J94_4runner] #638778 08/21/05 03:46 AM
Runningman Offline
You can get the NGK Iridiums plugs from Advance for $6.96.
They're part # BPR5EIX for my 85 4runner w/22re, I've been thinking about trying them out.
Weird thing is the iridiums carry a 3 month limited warranty and the standard plug carries a 2 year replacement warranty.
85 Toyota 4runner with some stuff...
[color:"blue"]Trail Pics[/color]
Re: Iridium spark Plugs pros/cons [Re: Runningman] #638779 08/21/05 04:02 AM
well, for $7each I might throw a set in next time. give'm 60K of use. It's actually cheaper in the long run. But I wonder if they really last 60K. I've tried Bosch platinum plugs before in my Vette & supra and HATED them. my vette had this "mystery starting problem". Very hard starting.. sometimes had to crank it 5 times to get it going. Buddy of mine told me it was the Bosch plugs and to try NGK V grooves or regulars and i did. never had the starting problem again. Only thing that changed was the plugs. So I've already been bitten by expensive plugs before.. that's why i'm weary now about iridiums.
www.celicasupra.com
Re: Iridium spark Plugs pros/cons [Re: J94_4runner] #638780 08/21/05 06:35 AM
ACES_HI Offline
I've had the Bosch platinum 4 electrode plugs in my 22RE for 100k miles now and theyre as good as the day I put them in! For all who say Denso and NGK is the only way to go I say not so. If you dont like changing plugs, go with Bosch. They work as well if not better than Denso.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.014s) Memory: 0.6414 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-11-19 05:32:44 UTC
