86 Carb'd toy pickup running like poop...PLEASE HELP!!! #639356 08/22/05 06:34 AM
toomanytoys Offline OP
I just bought an 86 toyota pickup off of my buddy for a good gas mileage truck to get me back to forth to work. He told me it needed new plugs, but when I started driving it, it seemed fine. It had plenty of throttle response, and would sit at idle all day long.................until I was going to my girlfriends house this weekend. She lives about 40 miles from me which requires alot of highway driving. As I was heading down 95 it bucked a couple of times when I got on the gas. The further down the highway I progressed the worst it got. It got real bad up any sort of hill. It would buck like a bastard. I changed the plugs today (the old ones looked fine), and took it for a ride with no problems.....................until I was again on the same highway heading home from my girlfriends when it started. I even sat in about twenty minutes of bumper to bumper traffic with no problems. It seems to only do this when it's been running for an extended period of time. As soon as I push the clutch in while its bucking it idles fine. Once the bucking starts it gets really bad when it's under a load. I'm thinking it's the cat. I had a new muffler and tailpipe installed the other day, but the cat. is original. Any info would help!!!!
Re: 86 Carb'd toy pickup running like poop...PLEASE HELP!!! [Re: toomanytoys] #639357 08/22/05 06:46 AM
kyle-22r Offline
if it starts bucking/sputtering under loads or going up hills, it sounds like it could be a clogged fuel filter, fuel pump going out, or your carb has its float level set too low.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 86 Carb'd toy pickup running like poop...PLEASE HELP!!! [Re: toomanytoys] #639358 08/22/05 06:55 AM
stock87 Offline
You also might take a look at your spark plug wires. They could be just out of spec enough that the prolonged heat from long drives makes them perform badly. I know my carbie bucked like someone was dancing on the brakes when the original wires finally died after 17 years.
OEM, NGK, or Denso are the best choices if you do determine them to be the problem.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 86 Carb'd toy pickup running like poop...PLEASE HELP!!! [Re: stock87] #639359 08/22/05 07:06 AM
Buck Offline
I'd have to agree with the Fuel supply being a problem. Had a similar problem years ago, was a old fuel line suctioning closed during freeway driving or under load. Car would idle all day long and in town driving was no problem, but as soon as I got on the gas it would sputter and buck like a bronco.
84 Ext. Cab Pickup.
Re: 86 Carb'd toy pickup running like poop...PLEASE HELP!!! [Re: Buck] #639360 08/22/05 03:57 PM
Edy Offline
I get my gas from the cardlock in town cuz its cheap but I get symptoms like yours if I use their premium gas. Evidently no one else does and it sits and gets water in it.
Edy from "Behind the Redwood Curtain"
85 4Runner 22re, mostly stock. Over 340K miles(SOLD for $4000 7/06)
98 2.7 4cyl 4Runner Bone Stock perfect 200,000 miles (alright, it has a HG and clutch in it's past)
Re: 86 Carb'd toy pickup running like poop...PLEASE HELP!!! [Re: toomanytoys] #639361 08/22/05 04:49 PM
coryc85 Offline
Not that this is the exact same as your problem, but my '83 would buck when Iunder a load when cold and then also at low engine speeds like in parking lots. I adjusted my valves, and the problem went away. Very cheap and easy thing to do.
83 4x4, 3" Lift, 33" Buckshot Mudders
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6816 MB) Data Comp: Off Server Time: 2026-06-20 21:44:11 UTC
