I told you guys I'd be back #639738 08/23/05 02:17 AM
L
laughinwillow Offline OP
Now that the tranfer case/ wheel issue is taken care of.... I have a generous condensation problem! I assume its from my AC ... but ... theres enough of it that when i moved my floor mat (passenger side) half the carpet is soggy! Uhg.... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: I told you guys I'd be back [Re: laughinwillow] #639739 08/23/05 02:33 AM
BigJim Offline
Could be one of four things..
1. The A/C is low on freon and iced up causing condensation to leak out of the cabnet when it melted.
2. Your condensation hose is holy or not attached anymore.
3. Your heater core is faulty and that is coolant on the floor.
4. It has been raining and that is rain water.
Re: I told you guys I'd be back [Re: BigJim] #639740 08/23/05 02:51 AM
RockJock Offline
Does it drip alot of water under the Jeep when running with the AC on? If not prolly 2 if so prolly not 2.
Does it smell of antifreeze? If yes prolly 3 if not prolly not 3.
Has it been raining? If yes prolly 4 if not prolly not 4.
<img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: I told you guys I'd be back [Re: RockJock] #639741 08/23/05 02:58 AM
L
does not smell of coolant .. and feels like water (i touched) and put a white paper napkin on it .. its water to be assumed ... no rain ... when the AC is running theres a little drip.
Re: I told you guys I'd be back [Re: laughinwillow] #639742 08/23/05 03:05 AM
L
The drip is under the front console on the passenger side ... one part of the guts up under the dash is quite hot while next to it is very cold.... errr ... sounds like i'm screwed for something ... lol <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: I told you guys I'd be back [Re: laughinwillow] #639743 08/23/05 03:59 AM
RockJock Offline
I would find the factory AC drain and make sure it is still connected. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: I told you guys I'd be back [Re: RockJock] #639744 08/23/05 04:01 AM
L
thank you <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I told you guys I'd be back [Re: laughinwillow] #639745 08/24/05 02:16 AM
KCjeeper Offline
Administrator
Yes, it's the AC drain. Likely plugged. It goes through the firewall just below the evaporator.
Randy Halvorsen
98 Explorer XLT
99 F150 4x4
90 BMW 735i
00 BMW 323i
47 CJ-2A
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6200 MB (Peak: 0.6980 MB) Data Comp: Off Server Time: 2026-06-17 03:35:56 UTC
