Page 1 of 4 1 2 3 4
5.29 gears noticeable improvement off-road? #640082 08/24/05 02:13 AM
DanWheeler Offline OP
i'm planning on getting a set of 5.29s and wanted to set my expectations - i'm sure there is a noticeable improvement on the highway but was wondering what to expect on the trail. I guess the difference between 4.65 and 5.29 is around 12%. Does that even feel different when crawling?
thanks,
dan
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: 5.29 gears noticeable improvement off-road? [Re: DanWheeler] #640083 08/24/05 06:36 AM
powerRam50 Offline
3.9 to 4.6 sure made a good diferance to me.
Re: 5.29 gears noticeable improvement off-road? [Re: DanWheeler] #640084 08/24/05 05:42 PM
CapnCrunch Offline
Here are the numbers (1st gear x t-case gear x diff gear = crawl ratio):
3.918 x 1.925 x 4.625 = 34.88 to 1 crawl ratio (stock)
3.918 x 1.925 x 5.29 = 39.90 to 1 crawl ratio (5.29's are the only change)
3.918 x 2.85 x 4.625 = 51.64 to 1 crawl ratio (2.85 t-case is the only change)
3.918 x 2.85 x 5.29 = 59.07 to 1 crawl ratio (both t-case and diffs are changed)
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 gears noticeable improvement off-road? [Re: CapnCrunch] #640085 08/24/05 07:26 PM
*drool*
Thanks a bunch for pulling the numbers together. I think i'm gonna order up the 5.29s here soon. I guess they're not going to make a huge difference on the trail but they'll help a little getting to the highway.
now i just need to find a V6 donor front axle.
BTW - whats the availability on those xfer gears? did they all get sold? who is distributing them?
thanks,
dan
1986 Montero 2.6l
Re: 5.29 gears noticeable improvement off-road? [Re: DanWheeler] #640086 08/24/05 07:37 PM
CapnCrunch Offline
Last I knew they were sold out but Mark Hardman was going to make more later this year.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 gears noticeable improvement off-road? [Re: DanWheeler] #640087 08/24/05 09:47 PM
Yellowhammer Offline
3.918 is first gear on the V6 V5MT1 5-spd tranny. The 4cyl KM145 5-spd tranny has a 3.967 1st gear and the KM148 auto tranny has a 2.826 1st gear. So your final crawl ration will be a little different using these numbers.
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
Re: 5.29 gears noticeable improvement off-road? [Re: Yellowhammer] #640088 08/24/05 10:00 PM
59.8:1 with my 5spd 4cyl stick... oooh, so close to 60:1!
thats gotta be enough torque to start breaking parts.
1986 Montero 2.6l
Re: 5.29 gears noticeable improvement off-road? [Re: Yellowhammer] #640089 08/24/05 10:18 PM
CapnCrunch Offline
Did not know that. Was always under the impression it was 3.918
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 gears noticeable improvement off-road? [Re: DanWheeler] #640090 08/24/05 10:28 PM
CapnCrunch Offline
Yes, and that's why I'm thinking I'll stay with 33's instead of moving to 35's. 5.29 gears will allow you to turn 35's but the downfall is that there will be less teeth from the pinion gear engaged into the ring gear. The pinion gear can become a weak point.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: 5.29 gears noticeable improvement off-road? [Re: CapnCrunch] #640091 08/24/05 11:44 PM
Lloyd Swartz Offline
5:29s are not going to break. They are still massive cogs, and mine have been fine for quite a few years, under harsh abuse and several broken axles. As far as specific difference, its hard to compare. I did the 2:85 t/case gears first. BUT, the 5:29s made a HUGEEEE performance improvement for the highway, and the transmission shift points. With 35s my speedometer is off no more then a 1/2 MPH, another advantage.
But if your making the choice, get 2:85s first, and 5:29s when you are ready for 35s.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6486 MB (Peak: 0.7689 MB) Data Comp: Off Server Time: 2026-11-16 01:18:57 UTC
