Tire Balancing #640171 08/24/05 05:41 AM
Kookadala Offline OP
Does anyone remember the old magazine article about balancing tires that stated a special machine was needed to balance large truck tires. I have had two tire shops balance my 35" tires and I still get a lot of vibration at freeway speed.
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Tire Balancing [Re: Kookadala] #640172 08/24/05 06:29 AM
Creeper Offline
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: Tire Balancing [Re: Creeper] #640173 08/24/05 06:51 AM
Yes, I think the GSP9700 is the correct machine. I will have to check to see if either of the shops I used has this machine. (probably not). I am leaving for baja on thursday so will be out of touch for a few weeks.
Re: Tire Balancing [Re: Kookadala] #640174 08/24/05 02:03 PM
Squeezer99 Offline
Re: Tire Balancing [Re: Kookadala] #640175 08/24/05 03:30 PM
garym Offline
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Tire Balancing [Re: garym] #640176 08/24/05 04:50 PM
So are the T100 wheels lug-centric also? I seem to recall that they are. I have contacted one shop that has the GSP9700 but it wont take 35 inch tires. I am waiting for another shop to get back to me. If the machine does not fit large tires then I guess I am stuck with vibration. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Tire Balancing [Re: Kookadala] #640177 08/25/05 04:00 AM
adam Offline
You sure it's tire balance? Missing weights or see where some slid? Make sure it isn't the IFS starting to complain about 35s and a trip up the 'con. Or rear? Are your blocks corrected for pinion angle?
I'm using BBs next go round. About a pound of Counteract/tire still isn't doing all the job that much of it should, and it's no more cost effective than a machine balance to use that much of it, less cost effective even. I bet it'd still work as advertised on radial 35s and basic steelies, though. 8 oz/tire for that size iirc, and it is silent.
~Adam
Re: Tire Balancing [Re: adam] #640178 08/25/05 03:04 PM
rmg Offline
Where can you buy Counteract. Sounds like something to try for the random vibrations my tires have. Balancing hasn't worked so far.
Ryan
95 T100 2WD ExtCab
All Stock
Re: Tire Balancing [Re: rmg] #640179 08/25/05 04:31 PM
adam Offline
Got a 6 Roblees down there? It's a truck/trailer supply store. Seems like it might be, but I have a hard time knowing what's a national chain any more.
Looks like you got Dugco with just a phone number, AMI in Cordova, Guffy Tire Supply in Chatanooga and 31 Inc. in Newcomerstown, OH.
Distributor Map
~Adam
Re: Tire Balancing [Re: Kookadala] #640180 08/25/05 10:29 PM
garym Offline
Most Les Schwab dealers have the maching. There are 3 in the Bay Area. Seems like they should be able to do the bigger tires.
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6367 MB (Peak: 0.7600 MB) Data Comp: Off Server Time: 2026-10-30 10:21:02 UTC
