Spittin and sputterin #640250 08/24/05 11:52 AM
Madcat Offline OP
My fiancee`s 93 2 door Cherokee with the 2.5L and 5-speed has stated acting funny, it'll run fine all day long until I have to get hard on the go pedal. I just did a tune up, replaced distributer cap and rotor,plugs and wire. I also put in a new fuel pressure regulator. I'm starting to think that the fuel pump or the ignition coil are the culprits.
What do you guys think?
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Spittin and sputterin [Re: Madcat] #640251 08/24/05 02:18 PM
JeePete Offline
Start with the fuel filter, if that don't help, get a gauge and test fuel pressure. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Spittin and sputterin [Re: Madcat] #640252 08/24/05 03:53 PM
BigJim Offline
Now and then one needs to replace the coil with the plugs! Modern engines run 100K on their plugs. And it just bout does in a coil!
But it does sound like the fuel filter. Do that first.
Re: Spittin and sputterin [Re: BigJim] #640253 08/24/05 04:57 PM
Madcat Offline OP
I should've added in that the fuel filter was replaced as well.
Re: Spittin and sputterin [Re: Madcat] #640254 08/24/05 09:33 PM
BigJim Offline
Ok dude just which PLUGS did you put in there? Many plugs are not compatable with your engine.. The factory knew what it could use and put em in right off..
Re: Spittin and sputterin [Re: Madcat] #640255 08/24/05 10:20 PM
Do you know how to check a TPS? I'd definatly test it.
Re: Spittin and sputterin [Re: BigJim] #640256 08/25/05 10:10 AM
Madcat Offline OP
Ok BigJim, my dad works for a parts store and told me the plugs I'm using are the propper heat range and everything. They are Champion copper cores....or sumthin. The engine was running even worse before I put those in, the ones that came in the truck when I bought it were 3 platinums and one regular,plus the dizzy cap and rotor were pitch black <img src="/forums/images/graemlins/barf.gif" alt="" />, very sluggish.
The engines got 221,000 miles on it and still runs strong but its giving me fits when I have to get to speed or get run over <img src="/forums/images/graemlins/scared.gif" alt="" />.
Sunder, I have a Haynes and the tool so I'll give that a try as well.
Re: Spittin and sputterin [Re: Madcat] #640257 08/25/05 02:47 PM
BigJim Offline
If it checks out Ok go ahead and get another coil from your Dad and try that. You did give a good case for a coil.. Not liking a load is the way most go away.
Re: Spittin and sputterin [Re: BigJim] #640258 08/25/05 06:22 PM
Madcat Offline OP
I priced one and it only cost $20, so I decided to go ahead and have a completely new ignition in there just to rule it out.
Alot cheaper than a fuel pump and a heck of a lot easier to replace <img src="/forums/images/graemlins/smile.gif" alt="" />.
I'll keep yall informed on if it fixes it or not.
Re: Spittin and sputterin [Re: Madcat] #640259 08/26/05 04:18 PM
Madcat Offline OP
Well, I take that back the coil is deep in the engine bay and you have to fight it off of its bracket or fight the bracket off of the block either way its a pain <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/baby.gif" alt="" />. after an hour and alot of cussing <img src="/forums/images/graemlins/zombie.gif" alt="" /> I got it replaced. Right off I noticed the idle was even smoother than before. I'm about to go road test it <img src="/forums/images/graemlins/cheers.gif" alt="" />.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6373 MB (Peak: 0.7609 MB) Data Comp: Off Server Time: 2026-11-02 12:33:17 UTC
