Vehicle weight #640538 08/25/05 01:14 PM
1
1jackleg Offline OP
has anyone scaled their truck before and after a SAS? Was curious about any weight difference.
Yes, you men were right. <img src="/forums/images/graemlins/lol.gif" alt="" /> - JL
I ain't real bright...
1990 Trooper LS, V6, Auto, 4door
132,000 miles 11/26/09
Re: Vehicle weight [Re: 1jackleg] #640539 08/25/05 01:19 PM
RobG Offline
I'd like to know what mine weights. I've always guessed I'm pushing over 5k now, easy. But i have never claimed my build to be weight consciencous! <img src="/forums/images/graemlins/smile.gif" alt="" />
-Rob
Re: Vehicle weight [Re: RobG] #640540 08/25/05 01:23 PM
strawmyers Offline
Isuzu Moderator
Oh, without question. The Amigo weighed in at 4020lbs at a local truck stop... and I haven't even added that much too it (relatively anyway). 5k is conservative for your monster <img src="/forums/images/graemlins/oink.gif" alt="" />
Sean Strawmyer
Re: Vehicle weight [Re: strawmyers] #640541 08/25/05 01:44 PM
RobG Offline
Oh well, let me rephrase then, I'm at least pushing 6k then. I've got an addition 2k probably in just axles, wheels, and tires alone.
-Rob
Re: Vehicle weight [Re: RobG] #640542 08/26/05 02:42 AM
Sammy Offline
Those D60's must weigh a ton. I would guess that my D44 SAS didn't really add too much weight to the vehicle. Although the axle and leaf springs do weigh more than what I took off, there was alot of IFS crap that was removed also. Now the larger tires, roof rack, high lift jack, and bumpers are a different story.
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: Vehicle weight [Re: Sammy] #640543 08/26/05 05:38 AM
maxwell417 Offline
My 89 Trooper RS is 3700 pounds. And the 90 4 door Trooper weighs in at 4400. But it has OBA, sliders, a winch, heavy front and rear bumpers. Both befores no afters.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Vehicle weight [Re: strawmyers] #640544 08/26/05 12:09 PM
Smiley Offline
Oh, without question. The Amigo weighed in at 4020lbs...
I knew something sounded fishy about the weight of mineà
I have to go get my tags renewed today û so, last night I was getting the paperwork together, and I noticed where the Gross Vehicle Weight is claimed to be 4000 lbs. on the registration.
I looked at that figure and immediately thought ôThereÆs just NO WAY!ö --- More than likely, someone somewhere along the line just guessed at the empty weight - because even before all of the mods (bigger tires, rock bars, brush guard, etc.) this thing wouldnÆt have tipped the scales at 4000 lbs. with Helium in the tires! (*metaphorically speaking)
I only mention this because the exact same sort of clerical error might also apply to someone else - therefore, just in case - for an accurate before & after, youÆll probably be better off putting it on the scales both times, rather than relying on whatever it says on your registration.
Six Isuzus, so far... still have three of them.
Re: Vehicle weight [Re: Smiley] #640545 08/26/05 01:34 PM
RobG Offline
Gross Vehicle Weight? are you sure? 4000lbs sounds almost low. GVWR (which is whats stamped inside the doorjam) is NOT your vehicle weight, but rather than how much your vehicle can weight at maximum capacity.
What I think you're referring to, and what this thread is about, is curb weight, or how much your vehicle weighs just sitting there. Not to be confused with GVWR.
-Rob
EDIT: Smiley, on a side note, you may have that weight rating on your registration due to titling issues. For instance, if your Rodeo is classified as a "car" rather than "truck", you probably can't be much more over 4000lbs. For instance, in NC, my F250 has to be registered with commericial/weighted plates since its GVWR is over 7000lbs... I pay almost $200 to tag it each year in order to cover it and a 10k lbs trailer.
-Rob
Re: Vehicle weight [Re: RobG] #640546 08/26/05 02:55 PM
paulevans76 Offline
my 86's owners manual stated curb weights under 4000. I doubted that, but only way to know for sure is to hit the scale.
88 Troop - Posing yard art
Re: Vehicle weight [Re: paulevans76] #640547 08/26/05 10:35 PM
TrooperJ Offline
Yeah, i really didnt expect these things to weigh that much. On the last Uwharrie trip, me and dad towed the trooper, and found that it weighed more, and produced far more strain on our truck than a 1954 Buick! Incredible. We were even worrying about our transmission by the time we got to Uwharrie. Needless to say, we will not be trailering this truck up there anymore...
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6391 MB (Peak: 0.7461 MB) Data Comp: Off Server Time: 2026-05-29 15:46:09 UTC
