quickest way to pull a V6 front diff / axles / brakes etc. #640790 08/25/05 11:49 PM
DanWheeler Offline OP
Are there any tricks to pull the V6 front diff, axles and brakes from a junkyard donor? I dont want to spend all day there. I have my hand impact wrench and the 8mm hex but i'm wondering if it would just be easier to disconnect the A arms and driveshaft and just drop the whole thing?
any advice appreciated
thanks,
dan
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: quickest way to pull a V6 front diff / axles / brakes etc. [Re: DanWheeler] #640791 08/26/05 03:19 AM
CapnCrunch Offline
Er...I haven't actually done it this way. The front end I got from the junkyard was a whole front end (the junkyard sawed through the frame, t-bars, and drive shaft and gave me everything forward). Everything was easy-access.
Thinking off the top of my head, and without the benefit of having my rig here with me at work for reference, I'm thinking:
-unbolt the drive shaft at the diff end and skid plates (both forward skid plates if possible)
-remove the calipers
-remove the hub assemblies (hub-locks, hubs/rotors, bearings)
-unbolt the axles at both ends and move them as far out of the way from the diff as they'll go
-unbolt the diff from the mounts and twist it out
-pull the shafts out from the inside
-have a couple pickle-forks and a BFH handy just in case
If you're doing the V6 brake upgrade as well you'll need the calipers, rotors, and booster.
I'm thinking I forgot to account for something (I had a shop completely rebuild my diff/axles)...
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: quickest way to pull a V6 front diff / axles / brakes etc. [Re: CapnCrunch] #640792 08/26/05 05:10 AM
Chris_J Offline
SAWZALL <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: quickest way to pull a V6 front diff / axles / brakes etc. [Re: CapnCrunch] #640793 08/26/05 06:47 AM
thanks Joe - i'm dreading doing the job. last time I went out to the yard to pull one, the hex keys on the hubs just stripped. That was before I had the hand impact wrench though.
I just noticed you have a SWB 2.6... i had always looked at your avatar and thought you had the LWB V6. Kudos for putting all that cool stuff on with the 2.6! Thats the direction I'm headed. It's taken me 4-5 years to stabilize the 2.6 but now that i've got it under control (so I think) it's time to get advanced.
1986 Montero 2.6l
Re: quickest way to pull a V6 front diff / axles / brakes etc. [Re: DanWheeler] #640794 08/26/05 09:24 AM
CapnCrunch Offline
Yeah, getting all that stuff can be a messy job. I just got lucky with getting the whole front end. Last time I pulled hub bolts at the 'yard I just locked some vice grips on 'em and turned. That did the trick.
Thanks for the kudos, Dan. It's been a long road but my 2.6 is really coming into its own. It's surprising how much its capability has so vastly improved over this last year. Stuff I couldn't dream of doing before is now a walk in the park. The little 2.6 isn't very muscular on the road but off-road at crawl-speeds it gets the job done. Nonetheless, I'm not finished by a long-shot. Plenty more work to be done before I'm finished modifying.
The avatar is a mini of this picture (photo credit goes to HMD...I believe he took this picture):
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6098 MB (Peak: 0.6915 MB) Data Comp: Off Server Time: 2026-11-16 08:41:39 UTC
