Body Lift Bolts #642134 08/30/05 01:22 PM
G
gt0987 Offline OP
I'm going to make my own body lift and I'm trying to plan my materials. I know I'll need 14 lift pucks (thanks Roger!). I've looked around but haven't found any info on bolts though. Does anyone know what bolt lengths are needed for a 1" body lift on a '90 ext. cab? I also gather that there are no weldnuts on the body/frame so changing to larger diameter bolts is not a problem.
Thanks.
David
Re: Body Lift Bolts [Re: gt0987] #642135 08/30/05 03:10 PM
John Smith Offline
You can make life easy for yourself and just buy the whole kit from Roger or pull your body bolts and measure them and purchase bolts that are X number of inches over stock where X is the amount of BL you are going to install.
I went the easy route and just purchased a kit from him years ago. He has already done the research and sells the most complete kit available for a Toyota truck or most any other truck for that matter.
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: Body Lift Bolts [Re: John Smith] #642136 08/30/05 03:56 PM
G
gt0987 Offline OP
I can get the material to make the pucks cheap at work and do it there myself. I like doing stuff like that so it'll be fun for me to make it. I figured with all the people on this forum that have installed BL's someone might have noted the bolt lengths. It's not too big a deal to pull the bolts and then go get replacements but I'd prefer to not have to stop halfway through the project to go the the store.
Re: Body Lift Bolts [Re: gt0987] #642137 08/30/05 04:32 PM
John Smith Offline
I understand the whole DIY ethic especially if you have access to some delrin. I recycled my original bolts years ago but I would imagine someone kept theirs. Good Luck!
John Smith 79 FJ40
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6003 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-09 21:46:15 UTC
