Page 1 of 3 1 2 3
4.88's tested and approved! #642406 08/31/05 04:24 AM
Kaptain Offline OP
First the cost:
$100 - 4.88 ADD front diff (Converted to non-add)
$125 - 4.88 V6 Rear
$120 - Shipping for both diffs (Could be worse i guess)
$16 - 2 Front Seals / 2 rear axle seals
$50 - 5 quarts of Mobil 1 Synthetic Gear oil
$4 - RTV gasket maker
$415 - TOTAL COST TO RE-GEAR!
Performance?
Jumping from 4.10's to 4.88's is awesome! I can actually
maintain my speed when going up hills! The 22re is much
happier operating in the stock powerband once again..
I'd say these gears are just right for 33's on an X-cab P'up
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: 4.88's tested and approved! [Re: Kaptain] #642407 08/31/05 04:50 AM
L
lookmomnobrains Offline
you stink!! i want 4.88 so bad. i have 4.10 in my 84 ex cab now with 33's. i also have 2 good 4.30 8" rear 3rd, and 1 4.30 front 3rd for ifs. in addition i have a 4.56 ring and pinion set for an ifs truck (front and rear). cant sell any of it either. i hadda switch to a s/a truck didnt i.... <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: 4.88's tested and approved! [Re: Kaptain] #642408 08/31/05 05:27 AM
OOP'S Offline
Your clutch is going to be a lot happier also!!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 4.88's tested and approved! [Re: lookmomnobrains] #642409 08/31/05 05:57 AM
matts Offline
I had 4.10's with 31's and I thought the only thing that saved me was my R151 transmission's 4.33 granny first gear. With 33's I could see your clutch and your rod and thrust bearings taking a beating. Hurry you need lower gears! -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: 4.88's tested and approved! [Re: matts] #642410 08/31/05 06:56 AM
G
Greg_Canada Offline
You know who needs gears? My cousin who has 37's on stock 4.10's, v6 5spd, amd i bet it will STILL beat any stock 22re.
89 4Runner
Re: 4.88's tested and approved! [Re: matts] #642411 08/31/05 07:02 AM
L
if anyone needs any of my stuff it would definetly help my 4.88 fund....lol <img src="/forums/images/graemlins/mrt.gif" alt="" /> pity da fool who dont buy his gears.
Re: 4.88's tested and approved! [Re: Kaptain] #642412 08/31/05 12:01 PM
G
gt0987 Offline
Where did you get the used 3rds?
Re: 4.88's tested and approved! [Re: gt0987] #642413 08/31/05 03:15 PM
Staceman Offline
Told you Kaptain. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Now you have Toyota brand 4.88 ring and pinions, (I here they are of pretty good quality, unlike aftermarkets!) Also already "broke-in". As ZUK told me, "run 'em, beat the piss out of them, no need for the break in procedure")
Re: 4.88's tested and approved! [Re: Staceman] #642414 08/31/05 10:56 PM
Kaptain Offline OP
I'm looking forward to wheeling with the 33's soon..
I'm just hoping the Front diff will hold up with the swampers...
(4.10 open w/ 31's showed some carnage,
Pics of that will be up soon) Hopefully Zuk can explain
that one to me..
93' Toy xCab
Re: 4.88's tested and approved! [Re: Kaptain] #642415 09/01/05 02:52 AM
Snowtoy Offline
Your trail running will be much nicer now too, you will bne able to crawl over things now that you used to have to gas it over. You should also find yourself not using the brakes as much on descents.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6379 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-07-14 05:22:57 UTC
