Ultimate rear 2 Gen Rodeo suspension setup #642486 08/31/05 08:06 AM
holger Offline OP
Last months, I was trying to figure out what would be the best suspension setup for Rodeo. I spent many nights measuring things and calculating the stuff. I was not completely happy about conventional Rancho 99179 rear application. Eventually, this is what I ended up:
1. Links: control arms are from StinkyFab, bent, with RE ends. Longer track bar, made by Matt.
2. Shocks - rear Rancho 9000X 99116, with both eye ends. Matt provided post-to-eye adapters. Front shocks are 99136s (longer then usual 99214s). 99116s are about 1.5" longer (on mounted length) than 99179s, which translates to about 2-3 longer downtravel. Also, the upper eye mount looks much stronger than the post mount of 99179s.
3. Coils - OME919 with 1" spacers. Together, they deliver about 4" of lift. OME919 without spacers are NOT long enough to keep the coils in place.
Also, without spacers, OME919 make less lift then my old OME913 with 2" spacers.
With this setup, the articulation is really huge. One downside is that I hit the gas tank by my driver side upper arm again - even with my bent arms.
The ride is good, better than I had before. I'll try to post some pictures soon.
Now, I have some spare parts which take space in my garage. SF Bay Area residents who need the following used parts, in perfectly good shape, PM me:
1. OME 913 coils
2. Rancho 9000X shocks: 99214 & 99179, front and rear pairs.
3. KYB shocks, stock length, wonderful on-road application.
4. Stock Rodeo coils.
5. Stock Rodeo trac bar.
6. Stock Rodeo upper/lower rear links.
7. Stock Rodeo sway bars, front and rear.
Oleg
Deceased Rodeo'02 4WD.
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: holger] #642487 08/31/05 10:32 PM
Scott F. Offline
PM'ed Ya <img src="/forums/images/graemlins/cheers.gif" alt="" />
1995.5 Rodeo V6 Auto
Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: Scott F.] #642488 09/01/05 12:33 AM
holger Offline OP
I sent the answer.
Oleg
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: holger] #642489 09/01/05 02:12 AM
kashlak Offline
you have mail <img src="/forums/images/graemlins/kewl.gif" alt="" />
2002 RODEO LS 3.2 4x4
32" KUMHO MTs
O.M.E. 919 PROCOMP ES9000
K&N FILTER
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: kashlak] #642490 09/01/05 02:54 AM
Jim_Paget Offline
Ok, guys, just using the forum to tell each other that you have mail is not what a forum is for. If you want to be notified when you have PMs, turn on the notification. If you want to know if you have email, check your email.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: Jim_Paget] #642491 09/01/05 09:22 AM
holger Offline OP
sorry.
Oleg
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: holger] #642492 09/01/05 09:29 AM
randii Offline
Get us some pics, man... I dig the thinking man's approach to mix-n-match, getting the best bits for YOUR particular setup.
How'd you lift the front enough to stay even?
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: randii] #642493 09/01/05 04:38 PM
holger Offline OP
I'll try this weekend.
I suppose yes. I have not seen this in action yet - it stands in my garage without rear bumper, which is in a paint shop right now. When I'll put the bumper on, I'll make the pictures.
Oleg
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: holger] #642494 09/01/05 05:51 PM
matthew Offline
worthless with out pics <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
let's see how it came togehter Oleg.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Ultimate rear 2 Gen Rodeo suspension setup [Re: holger] #642495 09/01/05 10:33 PM
Bansil Offline
What is the extended lenght of your shocks,how much travel do the rear ones have?
Thanks
oh' and where are the pic's <img src="/forums/images/graemlins/pfft.gif" alt="" />
(it's almost the weekend)
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6400 MB (Peak: 0.7601 MB) Data Comp: Off Server Time: 2026-10-26 02:51:13 UTC
