T-CASE PROB #642508 08/31/05 01:34 PM
4
4mudder Offline OP
My buddy has a 90 hilux surf w/ manual trans, manual hubs (converted from add) and his front drive shaft spins when not in 4wd. Is this a t-case prob or is there a solenoid or something since its push button 4wd that we should check first. Are there any typical probs w/ these that i dont know of. thanks in advance <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: T-CASE PROB [Re: 4mudder] #642509 08/31/05 10:03 PM
4
4mudder Offline OP
anyone?
Re: T-CASE PROB [Re: 4mudder] #642510 08/31/05 10:34 PM
LUV24BY Offline
If it's a shift transfer case, and he just switched to manual locking hubs then while the T-Case shifter is in 2HI or N then the front driveshaft will turn freely. If it's in 4HI or 4LO and you can turn it by hand with the hubs locked then I would look at the hubs not engaging.
When my T-Case is in 2HI and the front hubs unlocked I can spin that front driveshaft until my arms fall off!
John
P.S I didn't think the 1990 Toyotas came with push button 4WD! Got a picture?
This is my first time here, be gentle......
.....But play DIRTY!
1985 Toyota 4Runner
http://www.cardomain.com/ride/2066809 Check this if you want to see her!
Re: T-CASE PROB [Re: LUV24BY] #642511 08/31/05 11:26 PM
CraShYota Offline
on my 88 before i had my frotn shaft hooked up the pinion on the tcase would spin when not in 4x4. i think it just has to do with the fact there is still some resistance. i could easly stop it with my hands and hold it in place. not a problem i would say.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6009 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-10-22 12:15:49 UTC
