Front driveshaft question #642605 08/31/05 08:45 PM
Bustedback Offline OP
Will the front driveshaft fron an 85 work on an 86 with a SAS conversion? Or should I just plan on having one made?
Re: Front driveshaft question [Re: Bustedback] #642606 08/31/05 08:54 PM
CraShYota Offline
depends on how much lift you have and if your running a differnt engine//tcase then the one that the driveshaft came out of. I would plan on having a higher angle one made especaily if you dont have a highpinion thirdmember. I recomend Jesse at www.highangledriveline.com he made my front driveshaft for a decient price and hes redoing my rearshaft right now.. very nice guy and he does good work with all toyota parts.
its getting banged up and beat on but its holding up very well.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Front driveshaft question [Re: CraShYota] #642607 09/01/05 11:54 PM
Cool! Highangle is just up the road from me in Paradise.
How much was the front shaft he did for you?
Re: Front driveshaft question [Re: Bustedback] #642608 09/02/05 12:31 AM
4Crawler Offline
They generally run around $300 with your stock shaft. I had Jesse's dad's shop build mine (Paradise Driveline), since I went there by mistake. He built me two long-travel, heavy splined shafts for about $300 ea.
Re: Front driveshaft question [Re: 4Crawler] #642609 09/02/05 02:01 AM
CraShYota Offline
240 after core charge. brand new with 2 u joints and 12" spline
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6059 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-07 08:30:35 UTC
