Toyota Calipers #642656 08/31/05 11:41 PM
Kaptain Offline OP
I noticed that toyota makes a rebuild kit for the
calipers.. Anyone rebuild on before? I just put
pads on the front and noticed that on one caliper
two of pistons would not move, and the other side
had one that took alot of force to just move it.
I actually had to put an old pad in there just so
it would work.
So, do I Rebuild them or go with an Autoparts
remanufactured one?
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: Toyota Calipers [Re: Kaptain] #642657 08/31/05 11:46 PM
A
averkam Offline
I did remans because I was in a campground 600 miles from home when I realized that mine were siezed. About $60 at NAPA
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: Toyota Calipers [Re: averkam] #642658 09/01/05 01:06 AM
CraShYota Offline
u can get a new caliper for like 65.... just get a new one and give em your old one for the 20$ core charge
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Toyota Calipers [Re: CraShYota] #642659 09/01/05 01:49 AM
Kaptain Offline OP
I'm assuming my calipers are beyond repair anyway..
The caliper they had stocked was a cheesy ONE
piston design that was 35 bucks.. Guess I'll have
them order the 4 piston design...
93' Toy xCab
Re: Toyota Calipers [Re: Kaptain] #642660 09/01/05 01:51 AM
Stan_Marshall Offline
yes, definitely get the 4 piston version (which is stock).
advance auto sells remanufactured OEM calipers.
1994 4x4 22RE W56 truck
Re: Toyota Calipers [Re: Stan_Marshall] #642661 09/01/05 02:02 AM
NYT100 Offline
Toyota also offers remanufactured brake calipers. I think they are about $100 per caliper. That is a lot better than $200-300 for a new caliper.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
Re: Toyota Calipers [Re: NYT100] #642662 09/01/05 04:27 AM
W
Wildcat_4R Offline
I just bought a remanufactured one through AutoZone for $28.99. Found it on their website and brought in the printout to my local store. The price in their computer was $37. Showed them the printout and got it for the $29 <img src="/forums/images/graemlins/kewl.gif" alt="" />.
http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=loadPage
The one of the pistons were frozen on mine as well. Rebuilding them is relatively cheap but I think spending the extra 20 bucks and saving the time it takes to rebuild em is well worth it.
1987 4-Runner with a "slightly modified" 22RE
Re: Toyota Calipers [Re: Kaptain] #642663 09/01/05 04:49 AM
OOP'S Offline
If the place you went to said the caliper they had was one piston, run do not walk away from that place, they do not know WTF they are talking about. All 4x4's had four piston calipers. If you can, get the calipers with the four big pistons. Go to NAPA, stay away from the places that offer a "Lifetime Warranty", most of that stuff is junk. The warranty is not going to do you any good when you are in the middle of BFE and it decides to start leaking. <img src="/forums/images/graemlins/kewl.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Toyota Calipers [Re: Kaptain] #642664 09/01/05 06:07 AM
BuleToy Offline
Wondering about your problem? I may have the same issue. My front brakes are pretty much on all time I can barely turn the rotor w/ the tires off. I have replaced the calipers w/ another set I had in the garage. Could my brake "freeze" be caused from two sets of bad calipers or do I have another problem. Also noticed uneven pad wear, but I am assuming that could be from my old calipers. Anything sound familar?
Re: Toyota Calipers [Re: Kaptain] #642665 09/01/05 11:51 AM
foxtrapper Offline
If they charge for a core, it's not new, it's a rebuilt unit.
One piston calipers are 2wd. Have them check the 4wd listing.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6394 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-10-22 02:14:55 UTC
