trucky wont start.. #642814 09/01/05 12:57 AM
CraShYota Offline OP
so after my "fun" where i broke my ds i have started my rig once. it didnt start starter just clicked so i figured the batt was dead i jumped it and it started up after a few more clicks. anyhow it wont start again.. just clicks... it seams like there is enough juice all the lights are bright n eveyrthing but the starter just clicks. whats the deal with this...
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: trucky wont start.. [Re: CraShYota] #642815 09/01/05 01:43 AM
ChrisH Offline
Get a hammer and let that starter know who's boss<img src="/forums/images/graemlins/shiner.gif" alt="" />
then replace the contacts on it, 4crawler has a link about it somewhere.
Mebbe the brushes also?
<img src="/forums/images/graemlins/cheers.gif" alt="" /> -Chris
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: trucky wont start.. [Re: CraShYota] #642816 09/01/05 01:56 AM
BuleToy Offline
I have the same problem its intermintent though. Try unhooking the little electrical clip that goes into your starter. Then take a piece of wire, I use speaker cord, and run from positive battery terminal to the starter where you removed the clip. It should start up, don't forget to have the ignition turned on. If it works then your starter is good but electrical is bad or corroded, a common problem.
Re: trucky wont start.. [Re: CraShYota] #642817 09/01/05 01:56 AM
Kaptain Offline
Starter Contacts are probably worn out, very easy fix..
Check out 4 crawlers page ..
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: trucky wont start.. [Re: BuleToy] #642818 09/01/05 02:22 AM
do what utard said only wire it to a starter switch. that's what i did and it helps and it don't cost hardly anythign
Re: trucky wont start.. #642819 09/01/05 02:48 PM
ChrisH Offline
Sry to steal your post tyler...
Fellowsped: You're in Washington? Do you happen to know the Cushing or the Flood families?
Re: trucky wont start.. [Re: ChrisH] #642820 09/01/05 04:27 PM
smansfield Offline
had the same prob 2 weeks ago.was the starter contacts.
just the side the battery cable hooks to,but i replaced both $13.80 cdn.behind passenger tire there is a access plate,remove that and it will come out right over the a-arm. <img src="/forums/images/graemlins/smile.gif" alt="" />
1993 toy pickup xcab 4x4
Re: trucky wont start.. [Re: BuleToy] #642821 09/01/05 04:32 PM
84toyota Offline
If you follow this advice, PLEASE remember to put the truck in neutral... don't want to run over your own foot! <img src="/forums/images/graemlins/confused.gif" alt="" />
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: trucky wont start.. [Re: 84toyota] #642822 09/01/05 11:50 PM
Scerb Offline
I had this problem too. To test the starter, jump the two electrical connections on the starter itself with some wire,, if your contacts in the starter are good, then it will crank (as noted, be in neutral).
In my case, the starter was fine, but my battery connection was corroded. Right where the starter cable bolts to the battery. Could also be loose conections on the battery.
-Scerb
Re: trucky wont start.. [Re: Scerb] #642823 09/02/05 02:08 AM
yeh sorry to be stupid i looked and have no fn idea where the starter is on a 3.0 v6. the thing that is clicking is undermy dash on the passenger side.. one of the relays back there. i looked for the starter but i just donno where it is ... i feel retarded having to ask but i just dont know.. pic would help i dont do well with explantions. thnx guys.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6362 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-21 20:22:15 UTC
