What tire pressure? #643120 09/02/05 01:26 AM
bard Offline OP
What tire pressures are you guys running with on the streets? I just bought new BFG A/Ts and I would rather get a heads up from the voices of experience instead of wait and see if what I'm running will wear evenly. The only reason I'm even considering changing my usual 32/35 is because the max psi is higher on these than the previous cheapo tires that were on it.
TIA
Re: What tire pressure? [Re: bard] #643121 09/14/05 11:02 PM
ralleyclimber Offline
I dont have the same tires that you have but I think that mine are at 35 psi. One thing that I read here smile is you can put a line of chalk acrossed your tire with say ##psi and drive forward a bit and look at the ground to see how (the tire wear is) the chalk is left on the ground. And increase or decrease as desired.
Re: What tire pressure? [Re: ralleyclimber] #643122 09/15/05 03:04 AM
Denvertaco Offline
I have the same tires. I have ran them for the last 30K at 35 PSI front and back. They are wearing evenly and are holding up just fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Double Cab TRD.. ARB, warn winch, OME coilovers, Alcan leafs, Bilstiens, Sky E-locker guard, etc, bla bla bla
Re: What tire pressure? [Re: Denvertaco] #643123 09/15/05 06:09 AM
TacoYota Offline
I recently asked the same basic question and got some good info. That thread is here. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2004 Tacoma Xtracab 4x4 V6
JL Audio sound system
** Caution: Video camera mounted in grill **
My Mileage
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-17 01:55:47 UTC
