Re: 4.0 swap wiring [Re: mflint1513] #643328 09/06/05 01:04 AM
small block
Re: 4.0 swap wiring [Re: mflint1513] #643329 09/06/05 02:29 AM
BigJim Offline
Mflint... He used sb to isolate the small block engine from the big block and the 4-banger or even a six cylinder..
Them that knows engines calls em sb or mice engines..
The term comes from the 396/427/454/504 being named GM's RAT engine.. then the smaller engine (sb) would be any of the lighter, smaller engines. I think the Ford 302 would be a great install in a Jeep.
So he was asking why you did not install a small cu in v-8 instead of the 6 cyl... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4.0 swap wiring [Re: BigJim] #643330 09/06/05 06:03 AM
mflint1513 Offline OP
Thanks for clarifying. Why the Jeep 4.0? Since it's a direct bolt up from where the 258 used to be, it should be an easier swap. Plus, I didn't want to deal with a carb so I went with a fuel injected 4.0.
Since I'm looking for a long-term solution to my problem and I've had a 4.0 before so I just decided to go back to it.
My JEEP: Something that once looked like a 1985 CJ7.
Re: 4.0 swap wiring [Re: mflint1513] #643331 09/06/05 03:55 PM
BigJim Offline
You most likely made a wise choice.. I think I would have torn the old one down and stroked it with a 4.0 head and a GOOD camshaft. Then Maybe the offy intake with the little 390 4 barrel carb and one of those Calif exhaust manifolds with duals from the manifold..
I only would have done these changes to see what the final product was.. Your choice is prolly a far better daily driver. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4.0 swap wiring [Re: BigJim] #643332 09/07/05 04:42 AM
That was sort of my original plan. I tried to find someone that knew enough about engines to stroke it but everyone around here kept sayin' it couldn't be done. It's getting close to active duty time so I had to do whatever I could. It's all good though. I should have a pretty great running Jeep when it's all done. We just yanked the tranny out and it's going to the shop tomorrow. Axles went to the shop to get 4.10's and a rebuild...it should all start coming together next week! Thanks to all of you who have and continue to contribute to my fiasco!
Re: 4.0 swap wiring [Re: mflint1513] #643333 09/10/05 04:30 AM
cuervo25 Offline
it can be done hesco has the kit to do it and i belive they have a new head for more power also. they also have alot of other things for a stroked engine.
as for the wireing harness fiasco,i think maybe painless wiring may have something <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" /> good luck and be safe on active duty
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6151 MB (Peak: 0.7018 MB) Data Comp: Off Server Time: 2026-10-21 20:41:55 UTC
