Pulled out the sawz-all again #643696 09/04/05 03:17 AM
DC Offline OP
Well. It always hurts when I do the cutting at first and then the results make up for it. The rear bumber for the sports are horrible. THey are designed after the mini van for very low step in for the groceries. It was the first thing to always get hit. So it had to go. I'm working on a tube frame style with swing out tire carrier.
Before
After:
this what I'm going to make. Similar but mine is going to be welded on and will sit a little higher on the body.
DC
97Sport A/T 33's
locked front & rear 4.90
5" IFS Lift
Re: Pulled out the sawz-all again [Re: DC] #643697 09/04/05 03:37 AM
Lloyd Swartz Offline
Your truck should be Bad <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> for the SIerra Challenge.....oh, wait a minute that already happened <img src="/forums/images/graemlins/lol.gif" alt="" /> You definately have to work on your timing <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Pulled out the sawz-all again [Re: Lloyd Swartz] #643698 09/04/05 07:13 AM
DC Offline OP
next years Lloyd.. Next years.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
DC
97Sport A/T 33's
5" IFS Lift
Re: Pulled out the sawz-all again [Re: DC] #643699 09/04/05 02:49 PM
justice Offline
Thats what I'm talkin about! Just dont paint it yellow and you'll be good to go <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Pulled out the sawz-all again [Re: justice] #643700 09/04/05 04:01 PM
Sounds cool dat. BTW, If you bolt it using the stock mounting bolts it should still be as strong but removable for painting, mods, etc... at least that what I've found... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Pulled out the sawz-all again [Re: off-roader] #643701 09/04/05 05:21 PM
DC Offline OP
We'll look at it for the bolt on style.
And it will be black.
DC
97Sport A/T 33's
5" IFS Lift
Re: Pulled out the sawz-all again [Re: DC] #643702 09/04/05 05:34 PM
LRJ4x4 Offline
black is good, yellow <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Pulled out the sawz-all again [Re: LRJ4x4] #643703 09/05/05 03:10 AM
Angelo Offline
You should go with a white ARB and rear bumper. Would look good to color match it.
Angelo
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6267 MB (Peak: 0.7266 MB) Data Comp: Off Server Time: 2026-11-04 15:49:14 UTC
