Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Steering rod recall [Re: toyota4x4] #644941 11/04/05 02:42 PM
mr2td Offline
just got it back tonight, about perfect alignment now and with new tie rods and relay rod <img src="/forums/images/graemlins/notooth.gif" alt="" />
edit: got a pic of it, it was dark out though..
Question - did they replace your tie rods at no cost?
I'm planning on taking mine in soon. I think I need new tie rods, but if they are going to replace them under the recall campaign, I'm sure not going to bother buying and replacing them myself!
Re: Steering rod recall [Re: mr2td] #644942 11/04/05 06:39 PM
G
graeaglecrawler Offline
i called toyota and they said i would receive a letter but it has been 3 weeks. any body else have a similar situation?
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: Steering rod recall [Re: mr2td] #644943 11/05/05 01:23 AM
toyota4x4 Offline
I'm planning on taking mine in soon. I think I need new tie rods, but if they are going to replace them under the recall campaign, I'm sure not going to bother buying and replacing them myself! [/quote]
Yup, I was surprised they did it.. not sure they're doing that on everyones rig though.
89 Toyota pickup, 4x4, 5spd, 3.0V6
31x10.5 bfg's on 15x8 pacer rims
custom exhaust, k&n air filter
Re: Steering rod recall [Re: toyota4x4] #644944 11/05/05 09:29 PM
tkrispin Offline
Got mine done - apparently this is the only one the dealer here has seen so far. They couldn't align it b/c my idler arm needs to be replaced. $368 parts and labor. I'll do it for about $50 in my driveway...
Pics...
Tom -|- TLCA #12384 -|- '95 4x4 x-cab mini
Finally E-locked...
1987 Celica GTS liftback - stock for now
...never enough...
Re: Steering rod recall [Re: mr2td] #644945 11/09/05 05:17 PM
G
i was told today that it could be february b-4 i receive a letter and then proceed with the fix. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Steering rod recall [Re: graeaglecrawler] #644946 11/10/05 08:22 PM
mr2td Offline
I called Toyota's customer service number 800-331-4331, told them I had not received a letter since I was out of state, gave them my new address and got the letter about a week later.
Re: Steering rod recall [Re: tkrispin] #644947 11/10/05 08:23 PM
mr2td Offline
Pics...
If you replace the idler arm yourself will they then align it for you for free if you bring it back in?
Re: Steering rod recall [Re: graeaglecrawler] #644948 11/11/05 04:57 AM
Jeff G 89 Offline
Why do you need a letter? I just took mine to the dealer and told them I needed the recall done. They looked up the VIN, put the truck on a hoist to see if they needed to order the tie rods as well as the relay rod, and scheduled me for a few days later. There is no need for a letter as it all goes by the VIN code anyways. They thought they would need to replace the tie rods (due to rusty threads I guess??), but they ended up only replacing the relay rod. The whole thing was very easy. On the downside, my truck had never been aligned in 218,000 miles as far as I know and yet drove perfectly straight with no uneven tire wear. After the new rod and alignment, the steering wheel is crooked and it drifts left <img src="/forums/images/graemlins/angry.gif" alt="" />. I don't know if I should take it back and *****, or just re-align it myself after work. It will take me an hour or so, but at least it will be done right. Another weird thing is that I asked him to look up my VIN for previous warranty/recall work so I could see exactly what mileage the head gaskets and timing belt was replaced and the computer showed that my truck had never had any work done to it. I bought it at 150k and the previous owner said the recall work was done 20-30k prior. If I would have known it never got entered, I could have had them do the head gasket recall again before the campaign ended and gotten a cheap water pump and timing belt job done. Oh well, it looks like I'll have to do it myself. I think I have about 90-100k on the belt <img src="/forums/images/graemlins/scared.gif" alt="" />
'89 Toy 4x4 Xtra Cab SR5 V6 266k miles
'01 Tacoma 4x4 Xtra Cab 2.7L
'97 Toy 4Runner Limited
Re: Steering rod recall [Re: Jeff G 89] #644949 11/12/05 10:16 PM
I went to in and had The work done my truck drove good for the first couple of hours then when I drove over some train tracks it started to pull very hard to the right. I crawled under my truck and The CLUELESS IDIOTS<img src="/forums/images/graemlins/confused.gif" alt="" /> at Toyota forgot to tighten my lower a-arm bolts:8 and they were all out of whack. Now after about 2 mins of my time I have it perfectly alined. I guess if you want something done right you have to do it yourself (as long as you've got beer). <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Steering rod recall #644950 11/13/05 02:52 AM
kewlynx Offline OP
Not necessarily. It means if someone ELSE is doing the work, you open the hood or crawl around underneath and do a GOOD VISUAL inspection before you even drive off the lot.
Between being female and a former GI, those guys see ya comin'. That was my lesson learned before my tool collection expanded. <img src="/forums/images/graemlins/shame.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6458 MB (Peak: 0.7718 MB) Data Comp: Off Server Time: 2026-06-13 10:56:08 UTC
