1990 trooper steering column questions....
#647212
09/15/05 08:53 AM
Hey i was wondering if someone on this board cold tell me if i am supposed to be able to turn the steering wheel without the key i can also shift the transmission without the keys, both of these things can be done with the ignition lock cylinder in the lock position. its a 1990 trooper 2.8v6 Auto.
thanks Matt
Re: 1990 trooper steering column questions....
#647213
09/15/05 05:22 PM
#647214
09/15/05 07:02 PM
I can't turn the wheel without the key in.
'91 Trooper 3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
[Re: Storm Trooper]
#647215
09/15/05 07:08 PM
My 1990 Trooper steering wheel will NOT turn if the key is in lock, I can however shift.
Hope it helps <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350 1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50 1983 Chevy Blazer - Stock - $150 No Car Payments - PRICELESS
#647216
09/17/05 01:58 AM
I believe the steering wheel will rotate in the lock position if the key is still in the switch. Removing the key sets the lock on the column. Shifter locking came late on many imports.
#647217
09/17/05 05:16 AM
would a bad ignition lock cylinder cause the steering wheel not to lock? I can remove the key in any position even while it is running, do you think this might be the problem?
#647218
09/17/05 11:58 PM
Only if you loose the key when it is running! <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6044 MB (Peak: 0.6796 MB) Data Comp: Off Server Time: 2026-06-09 23:35:33 UTCValid HTML 5 and Valid CSS
