Heater AC fan, guess the problem #647432 09/16/05 03:20 AM
CMH Offline OP
Nothing.....and the fuse is OK?
It used to stop working every month or 2 for about 20 seconds. I would just turn it off and then it would work again about 20 seconds later.
So is it the switch, fan motor, speed resistor ?
95 T100
89 ext cab 22re 4x4 267K miles (for sale)
94 Land Cruiser Factory lockers
95 T100 4x4 ext cab
Re: Heater AC fan, guess the problem [Re: CMH] #647433 09/16/05 02:48 PM
jmoser Offline
Maybe the fan belt is broken ! ! ! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Heater AC fan, guess the problem [Re: CMH] #647434 09/16/05 08:30 PM
surlynkid Offline
95 T100
resistor.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Heater AC fan, guess the problem [Re: surlynkid] #647435 09/16/05 09:13 PM
Jake97T Offline
Anybody have problems with the light behind the climate control panel going off and on intermitently???
Not to hi-jack the post or anything... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Heater AC fan, guess the problem [Re: Jake97T] #647436 09/17/05 03:05 AM
thecat Offline
O I do..
Toyota master
Re: Heater AC fan, guess the problem [Re: Jake97T] #647437 09/17/05 04:21 AM
surlynkid Offline
i replaced my bulb long ago.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Heater AC fan, guess the problem [Re: Jake97T] #647438 09/17/05 05:13 AM
J_Bird Offline
Yea, mine would go out on my way to work, before daylight. I would wack the dash below the stereo, and it would come back on. Finally it gave up the ghost.
Very easy fix. Pop off cup holder, pop off trim around the control panel, pull off the glass looking cover, and there it is.
Take the bulb to an auto parts store for a match. Except for the trip to the store, its a five minute job.
Re: Heater AC fan, guess the problem [Re: CMH] #647439 09/17/05 05:20 AM
J_Bird Offline
CMH, My fan used to do the same thing. I just left the switch alone, and it would come back on by itself in a minute or so. After a couple of times, it hasn't done it any more (knock on wood). Good luck, J
Re: Heater AC fan, guess the problem [Re: J_Bird] #647440 09/18/05 02:21 AM
mmiller Offline
Mine did the same last year. It would cut off for a few minutes. It would come back on after a while if I didn't fool with the switch. It's been working ok this year.
1997 T100 4x4 SR5 5spd
Re: Heater AC fan, guess the problem [Re: mmiller] #647441 09/18/05 05:07 AM
CMH Offline OP
Mine did this a total of about 6 times in the last 12 months and always came back after 10 seconds.........
Last time it did it was 10 days ago and it still will not work. From what I have read the resistor is probably not bad as you usually only loose one speed at a time. I read a post that said the fan connection can come loose and I will try that tomarrow.
95 T100 4x4 ext cab
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6348 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-21 13:28:44 UTC
