CV Boot split........Repair or replace #648080 09/19/05 02:26 AM
1
1FastSS Offline OP
I have 143K miles on my truck. The front drivers side boot is torn and grease is coming out. I installed manual hubs at 75K and removed the ADD hubs. I don't offroad much but do go throught high water and mud a few times a year. Now the question: Do I just replace the boot (both?) or do I get a rebuilt CV axle and replace the whole thing since I have to remove it anyway? Should I do the ball joints as well? Thanks for your help......
My Truck
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648081 09/19/05 02:51 AM
I redid the boots on mine and it was a greasy mess, if I had to redo it I would of just gotten the rebuilt cvs and put them in, also if you have the $$ this would be a great time to redo your ball joints/tie rod ends.
Re: CV Boot split........Repair or replace #648082 09/19/05 03:11 AM
if you dont have the money for a new axle, repairing the axle isnt that hard...me and my brother did his after a branch punctured the boot..we replaced both the boots...it only took 2.5 hours...wouldnt take that long now after learning how
Re: CV Boot split........Repair or replace #648083 09/19/05 04:50 AM
Hecubus Offline
I found it much easier and faster to just replace the whole thing. Plus depending where you go you can get a lifetime warranty. <img src="/forums/images/graemlins/smile.gif" alt="" /> I got one at Kragen for I think around $65 and they told me even if just one boot goes out again bring the wole thing back for a replacement. I couldnt resist
Jed <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648084 09/19/05 04:58 AM
Talon84X4 Offline
I replaced that same boot on my old 4runner, it's cheaper to buy the boot and do it yourself, but easier to buy the whole rebuilt cv shaft assembly, about a $70 after returnining the core. Had to do that when one of the cv's exploded on a wheeling trip, now i've got a pickup with a solid front axel...<img src="/forums/images/graemlins/kewl.gif" alt="" />
'84 PU low & slow
Central Valley Crawlers
Re: CV Boot split........Repair or replace [Re: Talon84X4] #648085 09/19/05 06:14 PM
1
1FastSS Offline OP
Can I get it out (CV shaft) without busting loose the ball joints? <img src="/forums/images/graemlins/scared.gif" alt="" />
Thanks.
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648086 09/19/05 08:03 PM
I was forced to bust loose the ball joints on my 92 3.0. There was no other way to possibly get that thing out. However, my buddy says he got his out without loosening the ball joints on his 89 22re. Id be interested to hear what you come across since we have the exact same truck.
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648087 09/19/05 10:18 PM
Kaptain Offline
You can get a boot kit with the grease for 30 bucks a side ( The Parts Bin.com ) And it is actually OEM stuff. I had to unbolt the lower Ball joint and disconnect the sway bar to get it out (before the ball joint spacers were installed).
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648088 09/19/05 10:46 PM
4Crawler Offline
Thanks.
One option is to do the quick change CV mod:
- http://www.off-road.com/toyota/cheaptricks/quickcv/
Re: CV Boot split........Repair or replace [Re: 1FastSS] #648089 09/19/05 11:47 PM
Snowtoy Offline
It is far easier to just undo the top ball joint, everything then just tilts away from the vehicle. I know thge manuals don't call for this, but it is so much quicker and easier. If you don't, you spend a lot of time fighting with it trying to get it all back together. As 4crawler mentioned, now would be the time to switch the studs to bolts.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6339 MB (Peak: 0.7528 MB) Data Comp: Off Server Time: 2026-11-03 14:08:33 UTC
