making Yota pinion bearing separator from scratch....sort of. #648442 09/20/05 12:46 AM
ZUK Offline OP
I was brainstorming last night and a Katrina kit me! <img src="/forums/images/graemlins/lol.gif" alt="" /> I needed a bearing removal tool for a specific pinion bearing used on the 86~95 models. I was short a lathe and a milling tool.....so I thought of a way to use a 2.25" bi-metal hole saw and a drill press to drill the main center hole and also to mill out 2 steps to clear the bearing profile. Randys sells a nice set-up for about 350....this costs about 10 for the separator and 15 for the hole saw. Bearing separators usually can't capture the bearing evenly all the way around....the end result has been, in my case, a distorted/bent/damaged separator. This took over 2 hours....nawing away at the metal....wearing it down. It's just kinda cool and I wanted to share............. <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: making Yota pinion bearing separator from scratch....sort of. [Re: ZUK] #648443 09/20/05 02:22 PM
Nice Purpose buitl tool!
Oh and Thanks for your Great write-up page, I refered to it alot setting up my new 5.29's(4cyl front and V6 rear). the rear is working perfectly, but I haven't had time to install the front yet(3rd into truck).............Karl
Re: making Yota pinion bearing separator from scratch....sort of. #648444 09/20/05 05:28 PM
ZUK Offline OP
Sweet pattern Karl. I'm gonna guess and those look like the pattern of a Motive gear.....the ones that have the number "304" in the ring somewhere. Did you properly preload the carrier bearings?
<img src="/forums/images/graemlins/shiner.gif" alt="" />oops....I just hijacked my own thread. <img src="/forums/images/graemlins/notooth.gif" alt="" />
mostly stock
Re: making Yota pinion bearing separator from scratch....sort of. [Re: ZUK] #648445 09/20/05 06:12 PM
They were in a Yukon box so I'm not sure. the pinion had waxy goop on it I had to clean off if that means anything. and yep I preloaded the carrier bearing as per instructions(yours). looking at pictures sure helps, thanks
And now Back to the regularly scheduled Topic <img src="/forums/images/graemlins/smile.gif" alt="" />.......Karl
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5970 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-07 05:00:35 UTC
