Water in tranny ?? #648659 09/21/05 03:03 AM
FranklinP Offline OP
Hi all. I went a little to deep in water a couple of weeks ago, it was submerged to the door handles for about 5 seconds. It was fine for another hour then it just reved up and slowly stopped moving. I drained the tranny and found lots of water in it. I then took a line off the radiator and flushed it until the fluid was clean and clear, About 5 gallons. I refilled with dextron 3 and it was ok. Then I went for another ride and got wet same thing, except this time was just puddles. Drained flushed ETC... Tonight I rode and really didn't get wet at all and it is whirling and wont go , Drained fluid and it is clean and clear. I found the vent tube tonight and it comes out and runs fore ward to terminate somewhere that I cant feel too.
SO was my tranny ruined the first time I got water in it and now I am just wasting money flushing it? It is whining like a power steering pump out of fluid. May be going out when it heats up and the water crossings are coincidence.
How on earth does the pan come down to get to the filter? Looks like the fill tube is part of the pan??? Does that cross member come down?? Does it have a filter? Thanks for the help. Happy to see this board has grown since my absence!! Some pics of the other night: Ok it was a little longer than 5 seconds.
1989 Dodge Raider V-6, 33" Swampers.
Raider pics
Re: Water in tranny ?? [Re: FranklinP] #648660 09/21/05 04:15 AM
W
wyleone Offline
Here is a pic of a KM148 case w/o the bellhousing on it.
This is the location of the trans vent. It usually has a small plastic swivel fitting that then hooks to a 4 in long hose pointed toward the engine. It is only attached to the O/D harness. I have installed a hose on this swivel fitting and run it to the engine compt. The problem is water can still get between the swivel fitting and the case. I plan to find a fitting to fit directly to the case that fits tightly to stay water tight. (Future project that you may get to before I do.) If the o ring on the kickdown cable as it enters the case is dry or cracked, water can also get in there.
Most friction materials in transmissions are bonded using a water soluble adhesive. The friction materials will absorb the water somewhat also. The water also does not compress at the same rate as the trans fluid in the hydraulic circuits, thus causing slip. Not to mension that the water will become steam when it gets hot. Most transmissions that I have seen w/ more than a little water in it did not make it. The hurricane here on the gulf coast flooded alot of cars filling the transmissions w/water. I have water casualties coming out of my ears because the Mississippi dealers have not gotten back running at full speed yet. Believe me, water in a trans is a bad thing. <img src="/forums/images/graemlins/barf.gif" alt="" /> BTW if you didn't check the diffs and the xfer case yet, stand back, their vents are lower than the trans. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Water in tranny ?? [Re: wyleone] #648661 09/22/05 12:53 AM
Thanks for the reply, Tonight I went for a ride and got about 15 miles, then it began pumping fluid out the vent hit the exhaust and caught fire. Right side plug wires got a little hot beofre i got the extinguisher on it. My thought is the pressure is some how building up starving the pump for fluid causing the things to just rev. So I need to drop the pan to see if it uses a filter. Does the pan drop and slide out without removing that cross member? and if so does the fill tube stay conected? seems welded into the side.
Raider pics
Re: Water in tranny ?? [Re: FranklinP] #648662 09/22/05 01:03 AM
LRJ4x4 Offline
Fire? that's can't be good <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Water in tranny ?? [Re: FranklinP] #648663 09/22/05 01:22 AM
W
wyleone Offline
If you follow the dipstick tube up 4" you will se a seam, it detaches there when you drop the pan. There is an Oring in there and if it is dryed out it can let water in there too. The crossmember will have to be removed to get the pan off. Some have a gauze filter but most have a screen. If you are plugging up the screen you have a problem
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6088 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-11-16 08:38:39 UTC
