Steering Wheel shudder at 55MPH #648706 09/21/05 05:04 AM
dailyDriver Offline OP
After months of driving with a noticible steering wheel vibration and noticebly uneven wear on tires, I brought my '94 IFS 4x4 to a family mechanic. Two lower ball joints, new pitman, new idler arm, new steering stablizer, and repacked wheel bearings, alignment job, and $400 in labor. All this work was completed and the truck still drives with the same vibration. Th alignment isn't even true! Are the tires to blame? I can't afford to put much more $$$ into this truck now, but the front end still vibrates on the HWY.
Anybody know what maight be going on?
DailyDriver: '94 Xcab 4x4, 22RE, 139K miles, STOCK
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648707 09/21/05 05:13 AM
4Crawler Offline
Swap the front and rear tires, see if it improves.
Re: Steering Wheel shudder at 55MPH [Re: 4Crawler] #648708 09/21/05 05:21 AM
Tried that before the front end work, it made it worse.
I'd better put it back the way it was.
Thanks for the idea. Will rotating the tires regularly wear them back into regular shape?
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648709 09/21/05 05:23 AM
kewlynx Offline
You might also fall under the relay rod recall
Swap tires as 4Crawler suggests, but do a visual inspection under there, and follow the instructions for the recall.
**ubi apis- ibi salus**
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648710 09/21/05 05:41 AM
ldivinag Offline
if you still have ADD, check out the front axles...
they maybe on their last mile...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648711 09/21/05 05:45 AM
ldivinag Offline
oh one more...
brake rotors. see if they are beyond warpage...
leo d.
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648712 09/21/05 08:31 AM
Snowtoy Offline
Have you had the tires/wheels rebalanced?, Does the shudder go away above 55mph? What kind of condition are the shocks in? How bad are the tires worn?
Vibrations through the steering wheel is normally caused by out of balance tires/rims, bad shocks, tread seperations, or severely cupped All of the other stuff you had replaced tends to cause wandering, and uneven tire wear.
I would have the tires rebalanced, also have the rims balanced to make sure that one(or all) aren't bent. Also have the tire shop balance the tires for a higher speed(depends on the machine they have).
Re: Steering Wheel shudder at 55MPH [Re: Snowtoy] #648713 09/21/05 09:19 AM
ToyotaChris Offline
I do not clain to be a mechanic, or know what the hell i am doing, but here is my 2 cents. I had a similar problem and it was because I dinged up my drive shaft and it became unbalanced. It wasnt even bad, but that was my problem. Could be tire balance as well.
Re: Steering Wheel shudder at 55MPH [Re: dailyDriver] #648714 09/21/05 05:08 PM
MarkD Offline
Have you checked your steering wheel for too much free play? I think the spec is anything over 1 inch is too much. It is very easy to check/fix - see to posted '93 repair manual for details. I did this recently on my '93 and I was SHOCKED <img src="/forums/images/graemlins/kewl.gif" alt="" /> at how much more steady my steering wheel feels when driving the higher speeds.
'93 Pickup | 22R-E | 2WD| Yeah...it's my daily ride.
Re: Steering Wheel shudder at 55MPH [Re: MarkD] #648715 09/21/05 09:02 PM
I agree with the steering box play. You can do it yourself,just slacken the nut on the top and turn the screw 1/2 turn clockwise then try that. Another answer would be the steering damper. We have this problem with land rover discos in the uk and fitting a new steering damper is the cure.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6384 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-11-18 11:45:43 UTC
