Diff drop brackets and 2 Gen Rodeo #648798 09/21/05 08:52 AM
holger Offline OP
Did somebody used the diff drop kit on a 2 gen Rodeo ? Please share the experience. How difficult is the installation process (time, skill level, custom fabrications necessity) ?
Does the R&P steering must be touched in the installation ?
Does it make sence to combine the kit installation with ARB front locker installation, or the installation processes are unrelated ?
How much better the CV angles are ?
Thanks !
Oleg
Deceased Rodeo'02 4WD.
Re: Diff drop brackets and 2 Gen Rodeo [Re: holger] #648799 09/21/05 10:17 AM
Bansil Offline
1)Bigpoppax2 is going to do it to his 2nd gen before uwharrie.Custom fabing would include making the brackets if they are different than 1st gens.I would set aside a weekend to do this.
2)Nope
3)I would do all of it at the same time since most of the same parts will need to be taken loose.
4)Don't know yet <img src="/forums/images/graemlins/smile.gif" alt="" />
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Diff drop brackets and 2 Gen Rodeo [Re: Bansil] #648800 09/21/05 11:58 AM
Joe Darlington Offline
I have a set of brackets that I will be sending out to Joe next week to install and test for me.
Joe
A little old lady once asked me why I have those big heavy bumpers on my truck, I responded "if I bump into something, I win!!" "BTW, I did bump into a Chev Minvan at about 30 MPH...it lost!"
Re: Diff drop brackets and 2 Gen Rodeo [Re: Joe Darlington] #648801 09/21/05 08:53 PM
holger Offline OP
Joe and Bansil, please keep this board informed about the issue.
Thanks !
Oleg
Re: Diff drop brackets and 2 Gen Rodeo [Re: holger] #648802 10/29/05 02:11 AM
strawmyers Offline
Isuzu Moderator
Any updates on this? Off-hand I had always just assumed 1st gen and 2nd gen Rodeos used the same brackets... is that not the case <img src="/forums/images/graemlins/confused.gif" alt="" />
Sean Strawmyer
Re: Diff drop brackets and 2 Gen Rodeo [Re: strawmyers] #648803 10/31/05 04:46 AM
Starchild Offline
I deliverd the prototype brackets to Bigpappax2 this weekend at Uwharrie. I heard him say he'd probably get them in this winter to test them out <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Diff drop brackets and 2 Gen Rodeo [Re: Starchild] #648804 10/31/05 01:53 PM
Bigpoppax2 Offline
As soon as I can make up my mind as to locking the front or not I'll tear into the front end. I have a 4.77 front third to install, along with a 4.77 disc braked D44 that will probably end up with a Aussie locker.
I'll snap pictures and report back when I get into this.
Joe
Re: Diff drop brackets and 2 Gen Rodeo [Re: Bigpoppax2] #648805 04/12/06 08:57 PM
Bigpoppax2 Offline
Ok, better late than never I have done the diff drops on mine. I also installed a 4.77 front third and an ARB at the same time. There's no sense having to drop the front end more than once. I got my 4.77 rear end installed with an Aussie locker as well.
Tad, Joel(spacecab90), and I did the install at Uwharrie last Thursday and the only issue that I ran into was the diff was awefully hard to get back into position.
We ended up cutting a 45 degree angle off the bottom of the drivers side bracket. This allowed for some more clearance needed to get thing up and bolted on.
I'll snap some shots tonight and get them up. I have enough t-bar crank to clear 285's and my cv's are basically flat. Very nice to see flat cv's again. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Joe
Re: Diff drop brackets and 2 Gen Rodeo [Re: Bigpoppax2] #648806 04/13/06 12:04 AM
ducktrooper Offline
That sounds great! I've pretty much gotten all the parts I need to regear with 4.77's also. Only thing left is to buy rear ARB. Joe D is making me up a set of diff drop brackets and crossbar mod. Maybe you guys should all come to Memphis for Music Fest or BBQ Contest....and just a little wrenchin!
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: Diff drop brackets and 2 Gen Rodeo [Re: ducktrooper] #648807 04/13/06 01:11 AM
N
Nazrat Offline
Setup a date this fall or late summer smile
You found a wide axle I take it?
-Tad
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs
2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.planetisuzoo.com
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6444 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-02 08:04:47 UTC
