94 Rodeo V6 - Heater Core Removal Question #648886 09/21/05 08:27 PM
CIrrusnine Offline OP
What a bad design, plastic hoses on the heater core...
**snap**
Does anyone know if the heater core on a 94 Rodeo V6 can be replaced without opening the A/C pressure lines or removing the A/C evaporator?
Thanks
'94 Rodeo V6
211,200 mi.
Re: 94 Rodeo V6 - Heater Core Removal Question [Re: CIrrusnine] #648887 09/21/05 08:55 PM
CPOM Offline
yes if it is anything like a 92 Pickup. you can unbolt the heater core box from the firewall and remove it. You might have to unbolt the condenser assembly and move it an inch to pull it out but the a/c lines run through a gasketed hole in the firewall so disconnecting the hoses should not be necessary.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5873 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-05-29 22:25:36 UTC
